Gold Member Username: AsharfiPost Number: 1574 Registered: Aug-06 | All the latest Pansat bins for all the models are posted at More bins will be posted soon, such as Fortecs, Viewsats, etc ... stay tuned |
New member Username: Luv2meetPost Number: 3 Registered: Dec-07 | but not for the 2700 clone? I can't find it there. |
Gold Member Username: AsharfiPost Number: 1575 Registered: Aug-06 | Correct, no clones files out yet. I'll inform ya when it comes ... |
New member Username: Luv2meetPost Number: 4 Registered: Dec-07 | thank you sir.. appriciated. |
Bronze Member Username: Hades305Post Number: 21 Registered: Aug-07 | cs_228t for converted clones (2500-2700) out |
Bronze Member Username: Alime_123Afgh, Ghazni Afgh Post Number: 29 Registered: Oct-07 | Hi all Ariza autoroll fix came out Ariza700,750,800,700s Hi guys here you go I hope you all enjoy a great weekend! Here you go have fun! And Happy testing. Posted here first only on now i can see PPV Thank MINGO><OGNIM |
Bronze Member Username: Kimo74Post Number: 55 Registered: Jan-07 | hi all any new file for the pansat 2700 clones. I had a Fortec ultra and converted it to pansat 2700 clone. Now i am down. Is there any fix i missed, or we are down. please let me know |
Bronze Member Username: Jagr1234Post Number: 66 Registered: Nov-07 | read above |
Silver Member Username: Destine0429Quebec Canada Post Number: 350 Registered: Dec-06 | Hey AV. I got the latest bin for my converted 2500-2700. But alot of the channels are not working still. Just curious if it's just mine or not. |
Bronze Member Username: Kimo74Post Number: 56 Registered: Jan-07 | hey all are we still waiting for the new file for our converted Fortec ultra recivers to pansat 2700 yet ??? cs_228t for converted clones >>>> is this file for us or not.. plz someone answer |
New member Username: Sweetgirl78Post Number: 3 Registered: Oct-07 | Hello I have a Pansat 2500a converted to Pansat 2700. I tried both the 227 and 228 bins, but the remote doesn't work. What should I do? Do I have to wait for another bin? |
Silver Member Username: ViruscauserLeesburg, Georgia Post Number: 511 Registered: Mar-07 | Not a fair question SweetGirl. (1) You have to provide the FULL name of the bin you loaded because the days of a single 227 or 228 bin have been relegated to history. (2) "Remote not working". Does that mean it's dead, that it will not even turn your receiver on/off? |
Silver Member Username: Regio65Monterrey, Nuevo Leon Mexico Post Number: 151 Registered: Sep-06 | Turn off 6 seconds a turn on the back switch |
New member Username: Sweetgirl78Post Number: 4 Registered: Oct-07 | Oh..oops sorry... 1) I loaded x-87bl 071207 b75 227 api 2) Yes even turning using remote to turn on and off does not work. 3) Yes, I changed the battery |
Bronze Member Username: MississaugaPost Number: 62 Registered: Apr-06 | May be it needs new batteries |
New member Username: Sweetgirl78Post Number: 5 Registered: Oct-07 | Nevermind, everything works now... it was the wrong bin... I needed the CS_228T bin... thank you anyway! |
Bronze Member Username: Bruce69Post Number: 30 Registered: Oct-07 | I HAVE PANSAT2500A CONVERTED TO 2700 WITH THE NEW CS_228T BIN.I HAVE TO TURN OFF AND ON THE RECIEVER EACH TIME I CHANGE FROM ECHO 3 TO ECHO 4 AND VISEA VERSA.CAN SOMEONE HELP ME FIX THIS PROBLEM? THANK U |
Gold Member Username: NydasPost Number: 5852 Registered: Jun-06 | Abby: It seems people making the mistake of loading the real pansat BIN on a conversion, seem to survive without having to jtag! Your comments will be appreciated. |
Gold Member Username: NydasPost Number: 5853 Registered: Jun-06 | bruce : You will have to live with it, or go through the process of default settings hard reset (switch off/pause/on at the back) user settings Antenna Setup Power Scan. with a 50% chance of success. |
Silver Member Username: Espn3Post Number: 180 Registered: Aug-06 | Is GC working on CS_228T for converted Fortecs to Pansat 2700 ? Thanks. |
Gold Member Username: NydasPost Number: 5857 Registered: Jun-06 | GC works on Pansat 2700 - 227 BINs. I have no report of it on the 228 BIN. |
Bronze Member Username: Kimo74Post Number: 57 Registered: Jan-07 | hey Nalin Could you plz answer my question i asked in the previous post yesterday. I there a file out yet or no for our converted fortec into pansat 2700 |
Silver Member Username: Espn3Post Number: 181 Registered: Aug-06 | Nalin, GC is not working on FLUs converted to Pansat 2700 using CS_227_t...bin. It stoped this morning around 11.30am estern time. That's why I asked about the 228 code. BTW, what changes took place from 227 to 228 ? Thanks. |
Bronze Member Username: Westway11Post Number: 62 Registered: Aug-07 | w00t Mississauga |
Gold Member Username: NydasPost Number: 5861 Registered: Jun-06 | kamal : The latest file for conversions is CS_228T_lightning..... jvvh_leafs(BG)_228.... is also equivalent. They were supposed to fix the BEV ECM but apparently have not. Everything you need for 2500/Flu to 2700 conversion in one package. Instructions included. The latest Chancy CS_228T_lightning included. jvvh_leafs will be added when available. http://public.box.net/2500_full_kit |
Gold Member Username: NydasPost Number: 5863 Registered: Jun-06 | John Johnson: All GC stopped working very soon after latest BEV ECM. |
Silver Member Username: Espn3Post Number: 182 Registered: Aug-06 | Nalin, that's right. we should probably wait for CS_229_t...bin. hope they'll take care of us. |
Bronze Member Username: JkmagoPost Number: 42 Registered: Nov-07 | Me too loaded the Bin for original Pansat2700 on to converted Pansat2700 and had remote not working. Immediately realised that it was wrong bin. I reloaded again CS225 which was suggested by the One. After this I scanned my channel to see that its scans though no picture on screen. After this loaded the correct CS227 bin meant for converted pansat 2700. everything works fine. Thanks to The one saved. |
Bronze Member Username: Kimo74Post Number: 58 Registered: Jan-07 | hey Nalin i have downloaded Jvvh_Bruins(BG)_228 file. Is this the right file for the converted pansat 2700. i tried 2 loaders to load it into the receiver but the loader refused as it is unkown format. i used the loader that u put in the package you added earlier. Am i doing somthing wrong or what, and is our receiver should be working with this file or no.. please answer thanks |
Gold Member Username: NydasPost Number: 5881 Registered: Jun-06 | Kamal: The package is for those who have a converted or unconverted Pansat 2500 or FLU. The package I have recommended has very detailed instuctions in the package. It is called instructions.rtf Bring it up in your Word and print it out and follow it TO THE LETTER. |
Bronze Member Username: Silverlion80Post Number: 61 Registered: Nov-07 | what is the latest bin for pansat 2500 clone even the one before bev ECM thanks in advance |
Gold Member Username: NydasPost Number: 5883 Registered: Jun-06 | The latest file for 2500 clones is 294T. it will give limited channels. There are not going to be any more files. You can convert to 2700 and get more channels. For Pansat 2500/FLU converted to 2700 Everything you need for 2500/Flu to 2700 conversion in one package. Instructions included. The latest Chancy CS_228T_lightning included. jvvh_leafs will be added when available. http://public.box.net/2500_full_kit |
Bronze Member Username: Silverlion80Post Number: 62 Registered: Nov-07 | thanks nalin nayda |
Bronze Member Username: Silverlion80Post Number: 63 Registered: Nov-07 | another question do i have to use the jtag cable or the null cable to convert it |
Gold Member Username: NydasPost Number: 5887 Registered: Jun-06 | You use serial load with the straight cable (not null cable). Detailed instructions are there to read and follow. |
Bronze Member Username: Solano2008Toronto, Ontario Canada Post Number: 20 Registered: Nov-07 | nalin I have 228T bin file loaded on my converted flu to 2700 i got all the channels and after downloading i saw all the channels for one time and next time when i turn on my tv i am getting message no signal. What could be the problem do i need to download the channel master or something else is wrong |
Gold Member Username: NydasPost Number: 5891 Registered: Jun-06 | tell me: I am presuming you have CS_228T_lightning loaded. Turn autoroll and autoTP off and then a hard reset (switch off at back/30 sec/switch on). If this does not solve the problem, reinstall the BIN. CS_227T_lightning is fine, as there is no BEV anyway. |
