Username: Chichos26 Canada
Post Number: 1 Registered: Dec-07
Saturday, December 08, 2007 - 23:29 GMT I have a pansat 2500 clone = converted to 2700 my pc have only connector USB....which cable I need???
Username: Dude123 Post Number: 1493 Registered: Jul-06
Saturday, December 08, 2007 - 23:31 GMT well then you need a usb to serial adapter. Check you local electronics shop like the radio shack or the source or something
Post Number: 2 Registered: Dec-07
Saturday, December 08, 2007 - 23:41 GMT yes I now I need a usb to serial adapter but all cable usb to serial adapter they are equal.... all work for pansat 2500 clon converted to 2700
Username: Dude123 Post Number: 1496 Registered: Jul-06
Saturday, December 08, 2007 - 23:45 GMT yes they are all the same just make sure the one you are getting is compatible with windows vista if you are using vista. If you are using XP then its ok because almost all of them work with windows XP.
Post Number: 5 Registered: Dec-07
Saturday, December 08, 2007 - 23:52 GMT ok tanks man
