Dsstester-CS_226T_Lightning_100t_Series_serial
Username: Indopak
Post Number: 69
guys i just downloaded this fix from dsstester but no one confirmed that its working... did anyone else use this file yet, and does it work. i know most of the files posted on dsstseter works.... but just incase did anyone use this file? CS_226T_Lightning_100t_Series_serial
Username: Birdwatcher
Post Number: 555
go head, put it in your box and report your findings. Go Now. good luck bye.
Username: Nydas
Post Number: 5736
This release worked for a short while before the ECM yesterday afternoon.
Wait for the next release.
Username: Sparky41701
Chavies, Ky Usa
Post Number: 57
any ideal when nalin when it will be
Username: Nydas
Post Number: 5739
Nothing coming up so far.
When you see a release for genuine Pansat 2700, you can expect a similar one for the conversion within a few hours.
Username: Indopak
Post Number: 70
yea ur right guys... it didnt work :-(
Username: Tscon
Post Number: 71
Jeees, both 225T and 226T releases has been killed by DN/BEV ECM changes
for like 24 hour period, I'm just curious if DN
already start using daily ECM changes, then no
bins would work. Any thoughts?
