Pansat 3500 quality 0 need help
Username: Mike_m
Post Number: 43
i have a pansat 3500 loaded i did the b 80 then the new bin and i,m getting o% quality level is 27% my lnb-standard ,my lnb local is 10750, 22khz off, disqu is off, legacy is non skew -045, tp 1 position setting is disable.i know i,m close.to getting tv any help and thanks in advance
Username: Rtap
FL
Post Number: 1283
if you want to get both 110/119 change from 10750 to 11250.
heres a list that may help.
61.5W Echo 3 - use standard circular lnb - 11250 MHz
63W Estrela - use linear lnb, either universal or standard linear- 10750 MHz
71.8W Nahuel 1- linear lnb, either universal or standard linear- 10750 MHz
77W Echo 4 - circular standard lnb - 11250 MHz
79W Amc 5 - linear lnb, either universal or standard - 10750 MHz
82W Nimiq 2 - circular standard lnb= 11250 MHz
87W Amc 3 - --- linear lnb, either universal or standard - 10750 MHz
91W Galaxy 11- linear lnb, either universal or standard- 10750 MHz
91W Nimiq1&3- circular lnb standard= 11250 MHz
93W Intelsat 6- linear lnb, either universal or standard-10750 MHz
95W Galaxy 3c- linear lnb, either universal or standard - 10750 MHz
97W Intelsat5- linear lnb, either universal or standard - 10750 MHz
101W Amc 4 - linear lnb, either universal or standard- 10750 MHz
103W Amc 1- linear lnb, either universal or standard- 10750 MHz
105W Amc 15- linear lnb, either universal or standard- 10750 MHz
107.3W Anik - linear lnb, either universal or standard- 10750 MHz
110W Echo 8 & 10,X - circular lnb standard - 11250 MHz
111W Anik f2 - linear lnb, either universal or standard - 10750 MHz
116.8W Satmex5 - linear lnb, either universal or standard - 10750 MHz
119W Echo 7 - circular lnb standard - 11250 MHz
121W Echo 9 - linear lnb, either universal or standard - 10750 MHz
123W Galaxy 10r - linear lnb, either universal or standard - 10750 MHz
127W Galaxy 13 - linear lnb, either universal or standard - 10750 MHz
129W Echo 5 - circular lnb standard - 11250 MHz
148W Echo1 & 2 - circular lnb standard - 11250 MHz
Username: Mike_m
Post Number: 45
i made the change 11250 and still 0% can be doing somthing wrong
Username: Mike_m
Post Number: 46
where do i se if it says 110w
Username: Rtap
FL
Post Number: 1315
mike which dish type do you have.
Username: Rtap
FL
Post Number: 1316
mike in antenna setup you will see echo7 and echo 8
echo 7 is 119
echo 8 is 110
do you have any switches
Username: Mike_m
Post Number: 47
i have the dishnet 500 in antenna setup i go to echo 7 or 8 and i dont see 119 110
Username: Dimwitt
Post Number: 265
select echo 7 ,change 10750 to 11250 and diseqc port to # 1
do the same for echo 8, except use port # 2
Username: Mike_m
Post Number: 48
thanks rtap and tooter all is well watching tv and payperview
