To fta tester
Username: Chip_la
Post Number: 26
I have a viewsat plat.Missing channels 489 495 how do I get those in? Echo7 119.
Thanks
Chip
Username: Dimwitt
Post Number: 261
TP scan 12268
Username: Ke5aqn
Post Number: 1418
still MUST answer the following question
What do you mean MIssing? Are they missing from your receiver or when you try to view the channel it reads autoroll?
Username: Chip_la
Post Number: 28
They did show up a the channels but where blank, but since i did factory reset they are not there a all.If I need to scan a tp please give me instructions.\Thanks
Chip
Username: Ke5aqn
Post Number: 1420
did you do a sat scan after the factory reset?
Username: Chip_la
Post Number: 29
yes and those channels did not show up
Username: Ke5aqn
Post Number: 1422
make sure you have that transponder those channles are on and that your receiver receives the transponder ok.....what is your set up? 1 dish? 1 lnb? 2 lnb's? is it a dish 500? A motorized dish?
Username: Chip_la
Post Number: 30
direct tv dish 1 lnb 1dish echo7 119
Username: Ke5aqn
Post Number: 1423
Ok then just make sure that transponder is scanned then
Username: Chip_la
Post Number: 31
what tp is it and not sure how to scan it
thanks
Username: Ke5aqn
Post Number: 1424
489 channel "10' is on echostar 7 transponder 12268
495 Channel "10' is on echostar 7 transponder 12268
Both channels seam to me to show the same program at the same time Not sure
Username: Leafs
Post Number: 121
^ yea i think you are right ...
