Kaos 5050 is there a jtag type function
Username: Louwho31
Post Number: 15
i may have turned it off while it was still loading bin 155. is there any way to reset it?
thanks
Username: Dimwitt
Post Number: 263
If the koas shows any sign of life on the display, try this
turn off the receiver in the back, then at the same time you click load the bin, turn on the receiver.
Username: Louwho31
Post Number: 16
ill try that .. give me a half hour..thanks
Username: Louwho31
Post Number: 17
yesterday i had 4 dashes (faint) today only very dim power light. i tried several times to connect and auto detect while turning it on. the loader keeps saing to turn it on. thanks anyway.
i asppriciate your help lou
