Pansat 3500sd bin file needed
Username: Chiragkawas
CANTON, MI United States
i was looking for new bin file for pansat3500sd
i already have file 339 is not working does the file 340 is out or not if yes where can i find
please guys and girls if any one has it please post it for me
Username: Buz
Mississauga, ON Canada
Post Number: 11
It seems like it's not out yet. I've been looking for the new 3500SD Bin as well. I guess all we can do is wait.
When a new bin does come out, it will surely be there on www.future-fta.info though. So just keep checking there time and again.
Username: Lotusbawa
Post Number: 15
Remote for Pansat3500SD not working after updated to B-80. Any fix for it. Had new file BIN "X-05BL_071122_339_api_NOCARD" loaded couple of days. Remote still not working. Thanks in advance.
Username: Ke5aqn
Post Number: 1169
On your remote...did you check the batts? Put in brand new onesjust to be safe also you must hit the stb buttion on the top or the remote will not control the receiver...try that and let me know
Username: Lotusbawa
Post Number: 18
Yep....It works. I pressed STB button and i think that fixed my problem...Thanks "THE FTA TESTER".
Username: Ke5aqn
Post Number: 1171
Not prob thats why I stay here all day LoL
