DTV Phase 3 Dish 3lnb setup help
Username: Gcguy
I had DTV hd on 4 receivers in my house. Now I canceled and went and moved the dish to 110 and left every cable alone and hooked it to my pansat 2700 also have a 250sm but the other is more stable right now on their latest bins. I do get some channels but I thik my menu options are wrong ( i'v left them alone in
lnb type - standard
Legacy SW - none
22khz - off)
it has 3 lnbs 110 119 connected and a long 3d one.
I'd apprecciate any help. Thanks
Username: Rtap
FL
Post Number: 1215
alfons u will not be able to get 110/119 together with this dish type.if you want you need to change your dish in order to get both 110 and 119.
