Nobody has guts to answere difficult question
Username: Qwertyuu
viewsat plat blind scan gone with new bin. The channels like 611, 617 620, 651,662 and 663 with frequency of 603, 632 cant be scanned without blind scan as I only manage to get these channels with blind scan before. Can somebody help.
Username: Saqeeb9000
Post Number: 254
U CAN USE FREQ METHOD TO FIND THOSE CHANNEL...
U NEED TO ADVANCE SCAN... AND PUT EXACT FREQ,ETC..AND U WILL GET THE CHANNELS..
CHECK LK'S POST FOR REPUTABLE SITES..I DON'T KNOW EXACT NAME OF SITE TO FIND FREQ, BUT IF U GO ON THAT WEBSITE IT WILL TELL U FREQ,ETC FOR ALL THE CHANNELS,..
ADVANCE SCAN .....WILL SOLVE UR PROBLEM
Username: Pulp_fiction
Post Number: 207
go get channel master and find urself a good channel list and upload it
Username: Sjain80
Post Number: 87
you can find all the frequecies at lyngsat.C0m but it's no help. I already tried it..but I will give a shot to thrill solution..
Username: Mclinkus
Post Number: 36
[link removed]
has chanle master and frequency guides.
the files viewsat releases are only temporary to get thier customers back up watching tv.
the completed ones ( perhaps including blindscan)
will be released when they complete whatever it is they are working on.
Username: Ke5aqn
Post Number: 909
Channel master does not work very easily with our viewsat receivers..
You can use [link removed] to edit a channel list that you find in a forum..
I find THIS SITE a little easer to use for looking for transponders and channels than lyngsat for DN or BEV.
I also have plat and am disapointed in the removal of blind scan also a few other things I have found changed that I miss. I am waiting for total to open the forum's back up so I can post a list..I will keep you all posted here on results.
Username: Qwertyuu
THE FTA TESTER------------any luck with blind scan
Username: Ke5aqn
Post Number: 912
Shiraz,
Blind scan seems to be gone for now. I have posted in the "report bug's" post at total a list of things I found missing or different along with lots of other people. so we will just have to wait for results.
Username: Chadap
shiraz, make sure you are have following TP freq on Ech*Star 3 in order to get your wish list:
12297
12661
12632
Username: Qwertyuu
Post Number: 8
Thanks......FTA TESTER
Amtel.......Thanks as well. I can see all these frequency, but no signal strength.
