Who help kill the clones last March
Username: Pulp_fiction
Post Number: 193
Posted on 03-11-2007 by a -Knowledgable Tester -
Thought I would post this here as it might save some receivers..
Make of it what you will..
Viewsat warning !
Take Notice:
Do not use any of the current ViewSat bin/files.
Those files contain malicious coding designed to kill your box. It is not known at this time which models/versions are being targetted, Platinum for sure.
Recovering a dead box might not be possible.
Until such times a solution is found, do not attempt to load any new files.
ViewSat support site headed by the creeep WartHog approve of malicious coding. VS support site and its Staff, deny there is anything wrong, *******s.
(what do u think of this? i am running older bin, does seem to be more problems than normal in forums. is this malicious talk, r the real thing?
Posted By a SuperModerator
man, i just had to reply to this thread.... i bought a platinum in viewsats beginning. some call it a first generation platinum. like a old buddy , it's been around quite some time now. if they kill my buddy..i will be pissed. the true part about that post is....warthog is not a liked person. he likes it that way.
Username: Saqeeb9000
Post Number: 250
is it true........
Post Number: 199
Search the net the truth is out there for all to see LK hides under many names... he changed his name on dsscomunity from warthog to szot for a reason.
Username: Dry_dent_lure
Post Number: 172
thill = Dumbass Doreen (AKA Dumbass DJ)
