Channels scrambled or bad????
Username: Chicky3884
Post Number: 106
I downloaded bin 339 as it was my first time ever and it did work to an extent but Im still having some problems. 1. I'll be watching something and it goes off to the scrambled or bad channel and I have to change channels go back to the channel I was watching and turn the power off and on a couple times. 2. The time is right but the epg is an hour off ,for ex if its 9:00 I have to see whats on at 8:00. And 3. Im still missing comedy central and a couple others. Is there another bin I need or something to fix these problems???
Username: Charjam
Post Number: 248
i have pansat converted 2500 to 2700 with the 224 bin and i have the same problem.
Username: Pulp_fiction
Post Number: 191
the fact of it is. the older 2500's and clones have on a 1 meg tsop which is going to make it harder and harder to produce a 100% working bin they running out of room. so take what you got or upgrade.
Post Number: 107
Sorry I forgot to mention I have a 3500s does that help with any advice?
Post Number: 109
please????? Someone??? Anyone???
Username: Satgrl
Post Number: 690
do a factory reset check ur switch and scan again..or load a factory bin and then the newest and check ur antenna settings
Post Number: 111
HA HA HA now thats funny I actually just started a new thread to look for ya! LOL
Post Number: 112
whats a switch? and its the blind scan I should be doing right? And what settings should I change for the antenna? Thanks again
Username: Satgrl
Post Number: 695
HHAA which satellite are u using chicky?
Post Number: 114
echo 7 and echo 8. Is that what you mean?
Username: Satgrl
Post Number: 697
yeah yeah thats what i mean ...
Post Number: 115
Is that okay and do I neeed certain settings?
Username: Satgrl
Post Number: 698
yeah i guess i just change the port or whatever and try to get the signal right ...and then just scan...
Username: Satgrl
Post Number: 699
LNB TYPE: Standard
LNB Frequency : 11250
22 Khz: OFF
DiSeCq: OFF <- set to # 1 when instructed to do so.
SKEW: -45 <--- ignore this setting
TP: [ 1 ] 12223 v 20.000
Positioner Settings: Disabled
Satellite Scan: ALL
Username: Satgrl
Post Number: 700
Your Antenna Settings by Sat #
Sat Echo 3 Sat Echo 7 Echo 8/10
LNB Power on on on
Lnb Type dont know dont know dont know
Lnb Freq 11250 11250 11250
22khz off off off
TP Freq 12297 12224 12239
Search Opt cant find cant find cant find
Diseqc 1.0 port 4 port 1 port 2
Diseqc 1.1 none none none
Motor disable disable disable
Legacy SW none none none
Post Number: 116
ok Im going to try these settings,the signal looks better already so maybe that was the problem. The lnb frequency was wrong soo.... thanks again!!!
Post Number: 117
The Tp freq keeps changing and now its not giving me the option to save. I have perfect signal with the setting you gave me ,it just wont stay there.
