Viewsat bin failed help please
Username: Chip_la
Post Number: 20
when I load the new bin my viewsat screen says failed. I am using the same cable and did this twice before with no problems.Grateful for any help.
Thanks
Chip
Username: Koko_wawa
Post Number: 81
did you unzip this file? are you sure the cable is straight and not bend?
Hit PC-STB then turn on the receiver from the back quickly. Good luck
Username: Scabz
Knoxville, Tn Us
Post Number: 67
Make sure you put in the right file.
