ARIZA 700 fix ? Can anyone help
Username: Mont_eastwood
Post Number: 22
Username: Alime_123
Afgh, Ghazni Afgh
you can download autorol(293)it is wor for me i have ariza 700 and it is work
Username: Poochi425
Mis, On
Post Number: 32
alime buddy can u confirm if u an watch ppv/movies n sports and above asian channels with 293 ???
thx
Username: Alime_123
Afgh, Ghazni Afgh
Post Number: 12
Today it can get a few chanal .it can not get PPV today
Username: Tehrani
Iran, Tehran Iran
hi all
iam new here and i have Ariza 700.
i need ne autoroll for ariza 700.
some one can help me?
thanks alots.
Username: Ustaad_hc
Post Number: 311
wait......................wait....................wait
Username: Tehrani
Iran, Tehran Iran
Post Number: 9
hi all.
what is up?did you find some things a bout Ariza700? I did not
Username: Tehrani
Iran, Tehran Iran
Post Number: 15
D!SH 0101 - Last Update: 10/31/07 03:12 PM
00: D6 1A 24 BF EA 89 B9 29 3D 84 14 3A 30 8F A4 C0
01: 0C 7A AE 74 38 74 E1 27 18 51 F8 1A 5F 19 96 8F
B3V 0901 - Last Update: 10/31/07 11:34 AM
00: 47 FB 44 74 A3 FB FC 89 D3 08 FB F3 12 FB 6B D7
01: 34 96 C6 F7 62 EA 97 D7 89 CC 37 1B 33 72 F7 B2
Username: Tehrani
Iran, Tehran Iran
Post Number: 24
Try this site for faster keys
[link removed]
Username: Tehrani
Iran, Tehran Iran
Post Number: 30
DISH 0101 - Last Update: 11/01/07 11:35 PM EST
00: 9F DE C0 DC 51 74 62 2A 48 A1 48 CA 62 10 DD 05 Active/New
[link removed]
Username: Tehrani
Iran, Tehran Iran
Post Number: 32
1. Press Menu
2. Scroll Down to Parental Control, Press Enter
3. Press "i" key on remote, then enter pin number "2004"
4. Scroll down to Set Default Key, Press Enter
5. Scroll up to Nagravision, Press Enter
6. Press VOL Right twice, you will see Dish Network
7. Press CH Down once, then VOL Right Twice, you will now see Nagravision 2 displayed top left You are now at the key 00, Press CH Down once so you can edit the Key Data
8. Enter your new keys (write down the old ones to be safe)
9. Press Ok to store, then repeat with key 01
10. Press exit until you get back to tv, all channels will be available
[link removed]
Username: Vasu_vijay
Post Number: 17
Hi Friends,
My old bin for Ariza 700 was not working,so I downloaded the 2.93 Bin for Ariza 700.It worked fine with no ppv channels,but since yesterday it is coming as "Scramble Channel".So I manually entered the new keys 01: 25,8D....
But still it is not working.I switched my receiver and switched on.Its not working.Can someone help me plssssssss...
Username: Zork_99
GTA
Post Number: 81
Is the Autoroll setting still set to off?
Username: Fundoo11
Any Where, NJ USA
Try 300 bin file available in major sites.
Please note that this file will only work for 110 & 119.
File will NOT WORK for 61.5.
You have to find keys from this forum change it manually every time key change occurs.
