i just installed the new file it was working fine but just all of sudden i wasnt able to hear anything and it shows "1" on receiver display and then i just turned it off and now when i am trying to turn it back on it does not turn ON. Please help.
Never happened to me, my friend maybe u can try to download the file into your receiver again and make sure it reboot then unplug the box... when the loader says is complete, DO NOT touch your box... until it reboot and time goes back to 00:01
I loaded the new bin and got it working for about 10 minutes, then all of a sudden it froze and showing the number 2 on the viewsat box. So i turned it off. Now it does not turn on at all. Also i cant put any bins into it no more and doesnt get detected. The box is pratically dead now. The only thing working is the red light in the back.
i am having same problem too, the bin made my vs2000 go dead, only see red light, the loader doesn't detect the receiver anymore coz it doesn't even turn on, what's going on? was there a virus in the bin?
anyone know how to bring back my vs2000? i just see a red light glowing through the mesh on the viewsat but no digital display or anything when i turn it on
ok i downloaded the file from totalfta i installed the bin as usually mean i waited for it to be installed and then waited for 0000 and then i hooked it back to my TV it was working perfectly but after 10-15 minutes i wasn't able to hear anything but can see the picture and on my receiver display it showed 1 and no remote button was working i tried everything nothing happened and then i turned it off from the main back switch now when i turn it back on it just dead only thing is the red light at the back. i hope this helps in explaining the problem.
wtf , someone received a crappy working bin it's making the vs2000 go dead. I got my vs2000 to display on the front panel but rapidly turning the on/off switch at the back
Totalfta wouldn't just put fake BINs It is either yo didn't wait long enough for the full progress or those dam Nagra ECM team targeting VS receivers or maybe VS Team just totally screwed up this time.
I guess Cartier was right about the Funeral time
Solution: Need to J-tag it folks It is the only way to resurrect the late friend
I personally didn't bother loading that new bin cuz I detected hardware issues last week. I tried to warn people here. They took it as if I was enemy.
KING ,,,do u think this is the correct bin for my original pansat 2700A? do i have to do b-75 before i load this bin...i got this bin from ftabins*net help plz
greeny Super Moderator Join Date: Oct 2006 Location: Umm, the Green of Greenland of course. Posts: 1,617 Rep Points: 51
To the best of my knowledge, Viewsats are probably the only receivers that you cannot jtag. You have to send back to factory and you pay $40. The above statement is from memory, and I could be wrong. If I can confirm it at another site,I will repost here.
If it is total DEAD, i.e. no power at all, look inside and check the fuse. Viewsats are known to have had more than the usual power supply problems and checking the fuse is a simple thing to do.
