Scambeled or bad channel????
Username: Nlempb
Post Number: 38
pansat 2700....dn 110 and 119....all my ppv, hbo,encore, max,tmc, pretty much all channels say scrambeled channel......amc and local work though.. Do i need to update my box...its been since sept. 06..anyone with the same problem,let me know so im know im not the only one! thx to any and all who respond.
Username: Nydas
Post Number: 4238
Wake up, Rip Van Winkle!!! Read at
[link removed] OR
http://www.al7bar*tk OR
at many other sites, in the Pansat 2700 threads. After you have read for about 2 hours, you will have really waken up from your long slumber.
Username: Whoami
Post Number: 58
yes you need to update the receiver you can find all the files you need here
http://ftasolutions.com/forums/forumdisplay.php?f=36
Username: Rtap
FL
Post Number: 716
yes you need to upgrade your file.the most recent file is X-87BL_071023_B75_218_api_1.zip. its available at http://ftabins.net/showthread.php?t=10657
register is free. good luck
Username: Satgrl
Post Number: 122
RTAP is this file tester does dishnetwork all channels wirk does it have new PID thnxs
Username: Satgrl
Post Number: 123
TESTED*
Username: Rtap
FL
Post Number: 718
satgrl i have a 2700 and 3500sd. and both are working fine.
2700 is working with X-87BL_071023_B75_218 Dish/Bev Bug Fixed.
3500sd is working with X-05BL_071023_333 Dish/Bev Bug Fixed.
Username: Satgrl
Post Number: 132
hey are u for real are they working when did u load this? and which loader did u use thanks!!!!
Username: Rtap
FL
Post Number: 723
satgrl once you load the bin file go to your menu and check the keys.i'm up and running on both the 2700 and 3500
Username: Satgrl
Post Number: 135
oh thanks sooo muchhh!!!! u really helped!! can u please tell me what loader did u use?
Username: Rtap
FL
Post Number: 724
2700A loader_UPDATED.zip Loader (v27.02) and Factory Bin (B-75)
available at [link removed] (All receivers)
Future FTA - Blacklist's Site:
[link removed] (C00LSAT and All receivers)
DSS Newbies:
[link removed] (Pantecs,all clones and all receivers)
or go to pansat*usa the original site for pansat
Username: Satgrl
Post Number: 137
yah i had an fta receiver for about 6 years ..i noe alot is just i thought maybe u need a diffrent loader or something thanks for ur help though
