Fortec Star Lifetime Ultra
Username: Skyjayson
Post Number: 12
I have Fortec Star Lifetime Ultra
but, someone sets default the machine, i lost all my channel.
How I get my all fox sports and ESPN channels back? what blind scan do i do?
please help, thx
Username: Asharfi
Post Number: 893
Well, you need the latest bin for FLUs, but one of the older bins are working good with autoroll. Then, you have to scan your sats and you`re good to go.
Username: Skyjayson
Post Number: 13
scan your sats? would u be a little more specific, just wanna watch NBA games
Username: Lklives
Post Number: 12763
subscribe or pay somebody...if U don't know what a scan is, or how to do it..
Username: Espn3
Post Number: 94
Jayson, go to MENU -> INSTALLATION -> Blind Scan -> get one from Selected Satellite.
If you don't have anything under Selected Satellite, then go to Antenna Setup and select one based on how your dish is oriented.
Also READ through these threads. Good Luck.
Username: Skyjayson
Post Number: 14
thx, everyone
i dont know who should i pay for doing that for me
John Johnson, my problem is there aer so many different satellite, and i did scan some of them, but come out same channels.
Username: Dure
Mississauga, Ontario Canada
Post Number: 74
Pl read Indian Channels in this forum re- Blind scan
Username: Asharfi
Post Number: 894
Jayson,
You should know the name of the satellite(s) you're using and before you scan or blind-scan any satellite, you need correct Antenna Settings.
Username: Skyjayson
Post Number: 15
AV
so sorry spending your time, how do i find out my info of antenna? should i go to the roof to check out what satellite i am using. i am really dont knonw what to start, i did several blind scan of different satellites, it came out same channels
i used to have those fox sports and espn, just someone stupid doing set default.
Username: Skyjayson
Post Number: 16
still my problem is not resolve yet,
anybody helps? i tried some many differnt blind scan with differnt sattelite, still cant find fox sports or espn.
Username: Asharfi
Post Number: 928
Jayson,
How about you first convert your receiver to a Pansat 2700 and then ask for help because FLUs are dying and soon there will be no support for those receivers. You can easily convert your receiver to a Pansat 2700 via serial port.
Username: Nydas
Post Number: 4021
Jayson: Before you convert to 2700, do this:
Load 293T BIN in your receiver using BL updater 1.4.
Then scan any one satellite you were scanning before. future-fta site has erased their Pansat 2500 files, but
You can get these files at
http://www.totalfta.com
http://www.dsstester*com
Make sure you unzip the files before you use.
Username: Skyjayson
Post Number: 17
what specific wire should i get to connect FLUs to laptop? if any one would give me a link to purchase.
Username: Asharfi
Post Number: 937
New laptops don't have RS 232 serial port. So, I guess you have to use some USB to serial port connecter. And, if you have that serial port, you need this serial cable: RS 232 female-female STRAIGHT CABLE with 9 pins on both sides
Username: Skyjayson
Post Number: 18
should i buy this?
http://www.emtcompany.com/products/adapters/dxubdb9-usb-to-serial-db9-adapter-ca ble.htm?gclid=CMntpr6Hj48CFRUhgAodLkVjFw
Username: Asharfi
Post Number: 939
Yes, that's the cable. :-)
