Combining Digital Cable and Satellete signals
Username: Foxcroft
I'd be appreciated if somebody can answer my problem with combining digital cable and satellite signals in one cable.
I've done it using diplexers, but I lost HBO and other pay channels in digital cable.
In my understanding, diplexer cutting out some frequencies.
Any suggestions?
Username: Lklives
Post Number: 12600
U should have no problems with a diplexer...if U have HBO on FTA and cable, then U will have it, when using the diplexer..mine works fine..
Username: Foxcroft
LK, to be precise, I have ethnic, not dish/dave
television and digital Comcast package.
Username: Tapeman
New York City in-HD, NY
Post Number: 1548
It is cutting the old HBO (analog) from cable
I think it is ch 14 or 2-15
Not the digital channels that is for sure
I bet yo got modem interference
This is a rare one
But there are ways around it
The simplest way is to change brand Diplexer
Sometimes inline surge protector or stablizer
Must take voltage measurements on your cable
Post me your readings
Very simple readings if yo got a voltameter
Check this section to compare your wiring
https://www.ecoustics.com/electronics/forum/home-video/330353.html
Username: Foxcroft
I don't have cable modem.
Diplexers - exactly the same as on your photo, but without "King".
Talk to the fiend who is with dishnetwork, he said diplexer cutting out 800-1000 mgz range from cable side and this where those channels are.
Will try different brand.
Thanks guys.
