DN Adult Channels
Username: Jojogun
Fairfield, CA United States
Post Number: 299
I have just lost all of the adult channels on DN. I still have the premiums channels. Just wondering if anyone else is experiencing the same. All Bev adult channels are up and running.
Username: Chrisduclo
Post Number: 39
all is fine on pansat 2700a
Username: Tml2011
You shouldn't be watching those channels anyways. They are no good for your eyes.
Username: Hawaiian_time
Kanaka freak...
Post Number: 1540
Maybe your spouse deleted them!
Username: Joonkadanmon
Philadelphia, Pa Usa
Post Number: 33
guys, am having issues with my pansat 2700a, was trying to download new bin, receiver no longer reboots, it continues to display 5, did i FRY RECEIVER? if not, what did i do wrong? how can fix it? and please someone walk me through setting up again? thank you all in advance frustrated
Username: Jojogun
Post Number: 300
Jooka.....why you wanna hi jack my thread? Start your own.
Username: Hitman11
Boston, MA USA
hi guys I have a question is it posible to add more than 2 LNB on the same dish
Username: Hitman11
Boston, MA USA
does anyone know if there is a new bin out there the last one i had was a cpl months ago if u do can u plz give me the link or email it to me pls
Username: Rtap
FL
Post Number: 566
andy need more info on stb and setup in order to help.
Username: Jojogun
Post Number: 301
What is it with you guys? Don't you know how to start a thread? Hi jacking threads is discourteous.
Username: Hitman11
Boston, MA USA
ok i have the viewsat Platimun 2000 and i'm using echo sta 8 and 10 not sure if that the info I left out pls let me know if u find a new bin for this receiver
Username: Rtap
FL
Post Number: 569
andy go to ftabins.net and register and there you will find the latest file.
Username: Rtap
FL
Post Number: 570
jojo thats normal here.i had to get used to it.lol
Username: Jojogun
Post Number: 302
Ok...so it's normal....but I would NEVER hijack a thread that someone started with their own problem and insert mine, intirely different in nature, into that same thread. Color me courteous to my fellow board members.
Post Number: 40
jojogun... are channels on the same transponder as the adult ones working just fine?
Post Number: 41
all i can think of is to do a factory reset and blind scan your sats again after you reconfig your lnbs
Username: Jojogun
Post Number: 303
Ok....I think I've discovered my problem. There were high winds in the area last night and I think my dish got moved a bit because some channels come in clear and others are distorted. So...I have to go up on my roof and re adjust my dish antenna. Thanks for all the input guys.
Username: Hitman11
Boston, MA USA
is the platinum 2000 that old or out dated that no one has new bins for it
Username: Rtap
FL
Post Number: 573
andy the file is at the site i told you.
here is the link.
http://ftabins.net/forumdisplay.php?f=35
scroll till the end and you will see
Viewsat VS2000 Lite/Platinum
