Archive through September 17, 2007
Username: Lanxer
Post Number: 8
Hey, I've got a Pansat 2500 non clone. Would this work for it?
Username: Asharfi
Post Number: 782
Shen luong,
This thread is only for Fortec STAR Lifetime Ultra receivers. Yes, you can convert your normal Pansat 2500 to a Pansat 2700 via serial port. Please visit www.dssrookie.com and you'll get all the files that you need for conversion.
Username: Banti
Post Number: 185
thanks
Username: Mkvl1490
Post Number: 122
abby
im making directly references to uploading a new bin
after i loaded 209 the channels was gone
but i went back to 208, and now i have all my channels
so the next time i might have to jump to 210 or something
what box should i click in the channel master
Username: Viruscauser
Leesburg, Georgia
Post Number: 213
The 208 / 209 are just bins and they are bins for a converted box which now behaves as a 2700. Thus even when the jvvh210 comes out, it will be for the 2700 box.
Thus in your Channel Master, you now choose 2700 regardless of the bin number.
Username: Lklives
Post Number: 11825
I agree 100% with this below...people do NOT follow simple directions!...this is why most people are having problems!
the person
c/p ...from a member at dsscommunity
I think most people do MISTAKE by turning power on BEFORE they hit download, and that is why some people like me had error messages (poor following of instuctions).
Look at # 4 and # 5 at the first post and instructions:
bin 209 moded for converted 2500 and FLU
autoroll!!!!
big thanks to jvvh
instructions.........
1.unzip files
2.open loader
3.choose 209 jvvh
4.hit download!!!!!!
5.power on the box from rear switch
6.let display #on#
7.put a channel list or new scan
NORMALLY then next set the default key, and put autoroll ON...but now shut OFF the autorolls and manually enter the new DN key, cause Dishnet is morhing the 2nd digit of the new active key stating today ...Monday 10 Sept..
Username: Nania
Has anyone successfully loaded the jvvh kernel and application on an April 2004 FLU?
Username: Reggiep
Post Number: 9
Hey johnson i had the same problem as you it said connection error, the thing you have to do is turn on your receiver from the back and soon as the first b flashes on your receiver when you turn it on from the back press download in flash mode then you will have no problem downloading the file, it should work perfectly then.
Username: Lklives
Post Number: 11829
U don't even have to do that...
power OFF receiver with rear switch FIRST....
get bin ready and hit DOWNLOAD in your loader
NOW power ON receiver
FIRST power OFF receiver...then
1.unzip files
2.open loader
3.choose 209 jvvh
5.power ON the box from rear switch
6.let display #on#
Username: Sam5002
Ny, Ny Usa
Post Number: 21
How to do a factory reset on FLU converted Pansat 2700?
Username: Asharfi
Post Number: 786
Sam,
Please follow these setps:
- Go to MENU
- Then, click on Factory Setting
- Then, for the password, please enter 0000
- Then, click OK
Username: Nania
AV
Will this factory reset return you to its original boot kernel?
Leesburg, Georgia
Post Number: 225
nania factory reset will nuke your channel list - that's it. Your latest bin remains intact.
Username: Espn3
Post Number: 64
I have another question which probably was answered but I can't find it.
What loader you use for a FLU converted to Pansat 2700 ?
Right now I have the 208 bin ( loaded with the Fortec Star loader recommended by AV in his first post ) but now I have a Pansat 2700 and I simply don't know what loader to use to get 209 bin and future upgrades.
Thanks.
Username: Lklives
Post Number: 11884
Use the same loader...
Username: Johndo9
with the 209 cn i get the international channel on 61.5 ???
Username: Newmen
Montral, Quebec Canada
Post Number: 40
how about the new bin "211 bin"? it's good or not?
Username: Koku99
Post Number: 28
New 211 bin for FLU converted to Pansat 2700 is working good.
http://www.totalfta.com/forums/showthread.php?p=420224#post420224
Username: Teevee4me
Post Number: 8
What loaders can be used after conversion?
Username: Rtf
RC use the same loader that u used b4
Username: Koku99
Post Number: 31
Same loader you used for converstion. Blacklist updater 1.4.
Username: Laurad
Post Number: 26
I have not converted to 2700 still have 2500A using 294 bin number I put in new keys and it keeps autoroll up to 500, checked and re-checked keys have 2 channels NASA and Angel,How, do I get other channels in used ne keys from Sept 11
Username: Bones714
Somewhere fi...
Post Number: 369
BUMP,good info
Username: Pepito49
Houston, Texas Usa
hey you guys im new at this programming box i have just bought a pansat 2700a itwas working ok but now keeps saying wait for picture goes up to 300 then goes to chanel and starts all over again. try to put new keys
00/75 DE F8 28 05 81 5D 87 8C E7 06 4C 84 71 8D 88 <01/55 18 1A B7 FF 6C 4C 45 92 05 E4 53 39 D4 96 C2 I HAVE X.87BL API:75-2.08-EUBX BOOT VER:75 16 AUG 2007 PLEASE TELL ME IF IHAVE TO CHANGE FILE AND HOW TO DO IT . PLEASE HELLLLLLLPPPPPPP .THANKS
Username: Channelwatcher
Ontario Canada
Post Number: 18
Ok I need a little advise please I have read everything and tried to load the b75 boot to my 2500a .After loading with link from above all I get is night rider does anyone know how to fix this.
Ontario Canada
Post Number: 19
I dont see the b75 flashing
Leesburg, Georgia
Post Number: 233
Bruce see if you can get the jvvh_205 bin to load. If that loads successfully you should bee the b-7-5 after it reboots on it's own. It may seem to hang up for a long time (2-3 mins) with a 5 on display but don't touch it until it reboots on it's own.
If that works, load the jvvh_211 bin in the same way using the same cable and the BL loader 1.4.
Ontario Canada
Post Number: 20
great i tried to load the 205 and still night lights
Ontario Canada
Post Number: 21
actually it was one with link 208
Leesburg, Georgia
Post Number: 234
I know. The jvvh_205 will change your boot system from b60 to b75. The jvvh_208 was the current bin at that time but it does not roll anymore so you should use the jvvh_211.
If you still have the dashes (knight rider) try this: Switch off your box, get the BL loader ready with the jvvh_205, hit write bin and THEN turn on your box within the next few seconds. You might succeed in loading the 205 bin that way.
Ontario Canada
Post Number: 22
hey what happened to LK s post about all the retards that was funny. But can someone please help me with my night rider lights
Ontario Canada
Post Number: 23
I will give it a try best place to get 205 bin
issss? Thanks again
Leesburg, Georgia
Post Number: 235
http://www.dXXtester.com/download.php?file=2964
(Replace XX with ss)
Ontario Canada
Post Number: 24
Thanks abby
Username: Asharfi
Post Number: 792
Current status for Fortec STAR Lifetime Ultra receivers as of September 13, 2006.
Receiver Status: Working
Using Boot File: b75_m.bin
Latest bin: jvvh_211_pwTd.rar
Performance: Very Good
Dishnetwork: Working with autoroll
BellExpressVu: Working with autoroll
Updated channel lists: None
If there's any correction to be made, please do so.
Username: Destine0429
Quebec Canada
Post Number: 275
Just a dumb dumb question. Better to be safe than sorry. But the bin jvvh_211_pwTd.rar
can be used on the Pansat 2500a clone receiver as well. I would just rather ask and look stupid than to fawk up my box.
Username: Asharfi
Post Number: 793
Well, from what I know, this bin (jvvh_211_pwTd.rar) will only work on Fortec STAR Lifetime Ultra receivers that are already converted to Pansat 2700.
Leesburg, Georgia
Post Number: 236
AV the jvvh_pwTd.bin will work on any box converted from 2500 to 2700 using the jvvh method - from Genuine Pansats to clones to Fortecs.
Username: Cartier1
Post Number: 985
AV WHY THE SITE YOU GIVE KEEP SAYING WAIT 13 SEC FOR A DOWNLOADE AND THEN WHEN THE DOWNLOAD COMES YOU CLICK ANC U GO BACK TO THE SAME WEAIT FOR DOWNLOAD . ANY REASON WHY IT'S HAPPENING /
Username: Cartier1
Post Number: 988
i tried to help a friend to convert his 2500 to 2700,
with the same bl 1.4 loader i flashed first b75-m the modified and then i got night rider i flashed the 209 or 211m the modified one and still always night riders.
any sugssetion.
Leesburg, Georgia
Post Number: 237
cartier1 try the conversion using the jvvh_205 bin you'll get from my earlier post (scroll up). I had similar problems trying to load the b75m. Use just the file jvvh_205 and ignore the rest of the files in there.
If the b-7-5 loads successfully, load the latest jvvh_211 bin.
Username: Tinfish
Post Number: 117
LK, AV: I'm a conservative guy that owns a FLU (and only looking at DN)and looking at these posts makes me feel uneasy to convert my FLU to Pansat 2700. Do you think most of these problems are a result of operator errors (i,e. not following instructions properly) or are there inherent problems that one needs to expect till things stabilize. Like most people here, this ia a hobby for me and the thought of converting the FLU to 2700 excites me! But since I have only one receiver I dont want to run into a situation where I dont get anything over the weekend. Thanks for your great help!!
Username: Nydas
Post Number: 3733
tin fish: Why take a risk with your only STB?
Flu is working fine with BIN 294T. The key changes are a mere irritant,since you do not have to enter all the keys but only two change numbers.
Username: Jmill1948
Chester, Va Usa
Post Number: 1069
anyone tried using the new x-87bl_070912_b75_213_api ? I was wondering if it will work with the pansat 2500 converted to a pansat 2700.......just asking if you have can you report the out come thanks.jm
Leesburg, Georgia
Post Number: 238
jm: You cannot use that bin on a converted box.
Username: Starlight
Post Number: 15
have anyone noticed that the FLU (after 2700 conversion) doesn't respond to the remote when you try to turn it on?
Username: Rtf
Mine does
Username: Starlight
Post Number: 16
if it does turn on, all you get is a blank screen; you have to turn off/on from back to get it going again;
Leesburg, Georgia
Post Number: 239
Mine does too but the coder jvvh has said all clones are not created equal and that remotes of some (very few) boxes have reported problems.
Some remotes fail completely and on some remotes keys get all jumbled up - for example the Recall button may work as the OK button and the 7 as a 1.... you get the idea. Press all buttons, one at a time, to see if that is the case with yours.
Username: Starlight
Post Number: 17
the front switch on the box behaves the same way too;
Ontario Canada
Post Number: 27
Ok this is for Carerit 1 You have to now load a factory bin then load the 205 then the 208 then it will work if you blind scan all the sats
Ontario Canada
Post Number: 28
I just did it today and works great
Username: Lklives
Post Number: 11973
To upload already converted 2500's...
For converted FLU:
1. Turn your receiver off
2. Connect PC and receiver with serial cable. Make sure connection is good, port is working and choose appropriate COM 1, 2, 3 or 4.
3. Open loader
4. Attach new 211 bin for CONVERTED jvvh (version 2500 to 2700) receivers to loader
5. Turn on your receiver
6. As soon as you see the letter B on display, quickly click on download
7. Wait until upload is completed and receiver has ON on display. DON'T turn reciever off before you see ON on display!!
8. Scan satellites.
Username: Nania
Post the manufacturer date of your unit with your success or difficulty. It will help coders better understand how to serve your needs.
Username: Asharfi
Post Number: 797
Cartier1,
I uploaded the files using some online file hosting service. [link removed] is a file hosting website where you can upload any file or photos and share them with your friends.
Tin Fish,
Don't worry, a lot of people are converting their FLU to a Pansat 2700 because by doing this, you'll have a much better machine. The autoroll will work, and you'll get some new features. If you wanna convert your FLU to a Pansat 2700, then just simply download the files I've posted and try reading the instructions file atleast 3 times before you start your conversion. And after you finish your FLU - Pansat 2700 conversion, then just simply download the latest bin and that'll fix your autoroll problem. Just simply follow the procedure LK posted above when you're downloading any latest bin to your converted FLU.
Username: Zoro22
LK is great help, I trust him, ONLY. If you follow with this procedure he posted above STEP BY STEP, you should not have problems. If you do, then visit:
http://www.dsscommunity.co*/forums/
Delete * add m
And read, learn and apply/share knowledge!
Username: Zoro22
TIN, converting procedure is very easy, just follow with directions and use CONVERTED files, once you upgrade to 2700. You will have much better and easier unit. I killed my FLU few times, and "Angels" here put my unit back into new life.
Wow! I am "new baby" here and I am surprised LK stays here. Man, he is legend. I'm Missing Maple Leaf and some others...here. This is my post nr2.....yeaahhhh, I am new baby!!!!!!
Username: R0ss
Whats the latest and easy-est way to con-vert my FLU to Pan 2700.?
I have b75_m.bin and
LATEST FIX-jvvh_211_pwTd.bin
and FortecStarSTB .. is this ALL i need.?
Tnx
R0ss
Username: Aeayk
Thank you all
I found v 213
at
http://ftabins.net/showthread.php?t=8702
would that work!
thnakx
Username: R0ss
OK I downloaded :
jvvh_213_Td.zip (if yes do i have to rename jvvh_213_Td.bin so i can see it in FortecStarSTB or Blacklist Updater1.4)
Tnx
R0ss
Username: Espn3
Post Number: 77
ROss, the first posting in this thread explained VERY CLEAR what to do.
I used jvvh_211_pwTd.bin, I know nothing about jvvh_213_Td.zip, maybe someone else does.
In general a *zip file needs to be unziped, it contains the *.bin file; as far as I know you can't load a *.zip file.
*.zip files are used to save memory space.
Autoroll for Dn works great on the 211 code.
On the autoroll option keep Keycode=ON, the rest=OFF. Good luck.
Leesburg, Georgia
Post Number: 245
the jvvh_213_td.zip will have to be unzipped first and you should end up with a .bin file. DO NOT RENAME a .zip file to a .bin file.
The only difference between the jvvh_211 and the jvvh_213 is that GC rolls on the 213 but not on the 211. If you don't watch GC, the 211 will work just fine.
Username: R0ss
tnx jj,
i unziped 213 yes i know that..but its like jvvh_213_Td
NOT
jvvh_213_Td.bin
also the 1st post is old and has 208.bin not 211.bin.?
tnx/anyway
R0ss
Username: R0ss
Abby, 211 after you unzipe looks like:
jvvh_211_pwTd.bin
but 213 looks like:
jvvh_213_Td
unzipe both and see..
tnx
R0ss
Leesburg, Georgia
Post Number: 246
R0ss I got my jvvh_213 from dssrokie and it looks like this "jvvh_213_Td.bin" and that is exactly what your should look like. If it does you have the right file.
Username: R0ss
Post Number: 7
got from here..check this one out?
Leesburg, Georgia
Post Number: 247
Can't download, not a member. Does it look exactly like mine complete with a .bin extension?
Else, let it go for now. If you don't watch GC, you don't need the jvvh_213 anyway and jvvh_211 will do just fine.
Username: R0ss
Post Number: 8
it looks like yours but when i unzipe it it doesn't have .bin at the end...if i rename it with .bin (ex..)its ok.?
i cannot find dssrokie (file)?
tnx
Leesburg, Georgia
Post Number: 248
You'd have to join dssrookie (free registration) but that's the home of jvvh.
Here's the link to the file at dssrookie: http://www.dssrookie.com/forums/b-font-color-cd2626-2500-files-font-b/213bin-con verted-for-2500-and-ultras-by-jvvh-156214.html#post983848
Leesburg, Georgia
Post Number: 249
Renaming a file is often dangerous because you might then load a file you think is a bin but is actually a compressed file and you could end up damaging your box.
Username: Nydas
Post Number: 3737
ROss:
You can't just add a suffix .BIN to a file. Some of the suffixes are reserved for certain types of the file.
Better do as Abby says.
Username: R0ss
Post Number: 9
ok
thank you
u right
r0ss
Username: R0ss
Post Number: 10
213 from: http://ftabins.net/showthread.php?t=8702 is no good ! corrupted !
R0ss
Username: R0ss
Post Number: 11
ok finaly i got a good jvvh_213.bin.
1. i loaded b75 as stated in post 1.
2. my ird now is flashing b 7 5...nonestop,
i tryed flashing jvvh_213.bin but after 100%burned it tells me write failed! i did it 2 times, one w ird on and BL4.1 Loader and w write first and turned ON ird later.?
im getting a(| )straight line on left side of ird screen...when i turn it off it flashes b 7 5 nonestop....? what am i doing wrong ..?
Tnx / help
R0ss
Username: R0ss
Post Number: 12
i also tryed 108 and get same thing write failed {er2}...
help is my ird still ok?
tnx
R0ss
Leesburg, Georgia
Post Number: 251
If it's rolling b-7-5 continuously, your box is still ok. I had a few problems too after attempting with the b75 file.
Try a couple of times again turning the box on AFTER hitting the Write Bin. If that fails, you can try loading the j27_205_1.bin
Username: Satscanner
Beaversbush, Sportsmans P... Great White ...
Post Number: 3107
PPL, Pansat left you behind ,lied to you, ditched you.
At best you might get a picture for a short term.
DITCH PANSAT AS THEY DITCHED YOU !
Move on and get another manufature'ers box , you'll be much more happier in the long run .And watch tv, not a full time job trying to get tv.
Username: Thomas03
I did convert from FLU to 2700 and all worked well. However, I have 2 satellites, one pointing to 61.5 and the other to 110. The first is on disecq 1 and the other on disecq 3. No matter how I configure my satellites, I only get 61.5 channels. Could this be related to the conversion to Pansat 2700?
Username: R0ss
Post Number: 13
I did it all... i tried (j27_205_1.bin)too, nothing I still have b-7 5 rolling nonstop...it wont write nothing else...i don't know what else to do, if some wise guy knows what my problem is please let me know...
...i also get this {Sorry...Type File Inconnu...:-(}?
(i even tried to convert it back to a flu w no success). b - 7 5 still r o l l i n g ..
tnx / i give up for now.
R0ss
Username: Thomas03
I finally did a factory reset, setup the satellites and did a blind scan before scanning for channels. This time it worked.
Username: Nydas
Post Number: 3742
When using BL updater 1.4, I have always found the following technique to work.
When you are ready with the loader and the BIN, and the receiver is off, keep one hand on the switch at the back and the other on the mouse. Then turn on switch, and immediately click mouse.
Leesburg, Georgia
Post Number: 253
R0ss have you tried other loaders?
If all else fails, try loading the Pansat Factory Bin.
Username: R0ss
Post Number: 14
NN tnx for your reply,
i tried your technique no fix (same thing)!
im getting a(| )straight line on left side of ird screen, and using BLUPDATER1.4 after 100% i also get WRITE FAILED [ER2].
tnx/anyway
R0ss
Username: Lklives
Post Number: 12011
Hey johnson i had the same problem as you it said connection error, the thing you have to do is turn on your receiver from the back and soon as the first b flashes on your receiver when you turn it on from the back press DOWNLOAD in flash mode then you will have no problem downloading the file, it should work perfectly then.
Username: R0ss
Post Number: 15
LooK,
I have done all that more than 10 times ..
no sir its NOT true.
tnx
R0ss
Username: Lklives
Post Number: 12022
well sometimes it may take 30 times...this is NOT Plug N Play...u must be persistent....thi s is called testing!...and if U cannot do the conversion , then stick with your dinosaur 2500 or its clone...or dig into your pocket and buy a REAL receiver, and quit being so cheap!
This is a VERY simple task, that thousands have completed successfully...obviously U are DOING SOMETHING WRONG!...the directions cannot be any simpler here...read the FIRST post here...it applies to FLU, all clones and the actual 2500...
Username: R0ss
Post Number: 16
LK, here is where i am after flashing 208 following directions from 1st post: i'm getting a(| )straight line on left side of ird screen.?
tnx
R0ss
Username: Juancho
Niagara Falls, Kashabowie.K... MOY
Post Number: 1482
I founded this method posted I don't remember where.It works for boths April 04 FLU units.It works this way.The file jvvh-211 has to be loaded on top of 205 file using the 2700a to 2500a loader. Select 211 file,it says unknown file type ,click ok, make sure"APP file only" is selected,then after the STB has completely booted up showing channel # click download...the file could be download as it should, ,, the STB will reboots with the 211 file loaded. , This method worked in my FLU. try it
Username: R0ss
Post Number: 17
Juan R, Yes my FLU is "April 04 made in Korea" Good unit NOT clone!
which 1 is that? (i have FortecStarSTB and Blacklist Updater1.4)
what u mean by that?
and did you have tha problem I have?
tnx/I feel a little better
R0ss
P.s. look for that link please
Username: Kimo74
Post Number: 50
Hi AV
Thanks for your help. You are doing a great job.
Leesburg, Georgia
Post Number: 254
R0ss here you go: http://www.dssrookie.com/forums/b-font-color-cd2626-2500-files-font-b/2700-to-25 00a-via-serial-port-convertion-151134.html
Username: R0ss
Post Number: 18
Abby,
i tried that loader too..its not doing anything cannot write to stb same thing.
tnx/anyway
R0ss
Username: Asharfi
Post Number: 798
Thanks for the feedback, Kamal. But, you should also thank LK and Abby because they're the ones who're helping newbies here inside this thread.
Username: Asharfi
Post Number: 799
Ross,
Here, please take my email address asharfivig@msn.com. I'll come ONLINE tomorrow if you want LIVE instant help, then just add me on MSN and come online and I'll stay online from 5:00 PM - $10:00 PM.
Username: Tombrown199
Hello all members
i did converted my ps2500a , but made 1 big mistake
when download the bin j27-205-1bin after it shown
COMPLETED while the knightrider still running,i accident turn off the switch at the back , what i have now is only black and not things else even try to do some other thing but no power at all
please give help thank you all
Username: Nydas
Post Number: 3761
dan ong :
I think you should jtag, then load the Pansat original BIN, and perhaps BIN 281 or later, do the user setup and then do conversion again.
Wait for reply from AV before doing this
Username: Lklives
Post Number: 12046
No need to wait for anybody!...nalin , has no clue and is afraid she will say something wrong...
tom brown aka dan ong...IF U have absolutely NO power , then U must perform a Jtag, its that simple...otherwise U must force the boot or factory file on it...then proceed with the conversion correctly..
Username: Nydas
Post Number: 3765
dan ong :
Don't listen LK. She is pest and wants to interfere in everything I say or do. She has not done the conversion and does not own a Pansat 2500 or 2700. This is new twist in BIN loading and AV and abby have done it, so wait for an answer from one of them.
Username: Nydas
Post Number: 3766
LK: You are a sex perrvert . Stop chasing me. You don't have a clue about this conversion, the changed software and what it does, and have the stupid audacity to try and confront me. Confront,if you can, with scientific information. You only know C/P, so go find it - specific to what dan ong's problem is, otherwise buzz off
Username: Lklives
Post Number: 12047
nalin...how do U know what I own?....U tell me what I own...and what procedures I have ever done on any receiver....are U clairvoyant?
I know that all U know is just shooting your mouth off about entering keys and using an old 280T bin for old 2500 clones... basic FTA 101 using a dinosaur method....and then copy and paste all my posts..
