Help - setting up 4 dishes/4dual LNBs to run on 5 receivers
Username: Blierso
Post Number: 10
Hi!
I'm trying to hookup 4 separate dishes to run on 5 receivers, the simplest way possible. Currently I'm using A/B swithes, DiSeqs and Diplexers. I just bought a 5x8 Multi-Switch (Kathrein EXR-508) that was advertised as 4 satellite inputs and one terrestrial input, that turned out it can only handle 2 separate satellite dish inputs.
I have the following dish setup:
- two 18" dishes, @ 91W and 110W (standard LNBs)
- one 33" dish @ 119W (standard LNB)
- one 39" dish @ 97 W (universal LNB)
Receivers:
- 3 Viewsat Xtremes
- 1 Pansat 2700A
- 1 Pansat 2500A
Where can I find a Multi-Switch that will work with the above setup?
I'll appreciate any feedback.
Thanx
