Need Help Badly
Username: Jryevols
Little rock, Arkansas USA
Post Number: 27
I truly need advise that will help me. I have PANSAT 3500SD. It came with the b-80 loaded. I have gone to pansatusa.com and downloaded the bin file. It says that it loaded complete. I scanned the birds and it loaded 240 channels. It will pick up Angel or free tv. I go to parential control to look for the second pin , and it doesn't show. I tried putting in 8282 and it just returns to free channel. Can anyone help me please , I can't get to the cas system to load keys. What else can I do? Have I downloaded a bad bin file. Where can I go to get one that will work...thas free..please help
Username: Lklives
Post Number: 11978
Load the 328 bin and scan the satellites...pansatusa has ONLY factory bins...
Username: Jryevols
Post Number: 28
WHERE CAN I GET 328 BIN FILE
Username: Lklives
Post Number: 11982
All these sites ALWAYS have the latest files, bins, how to's, manuals, guides, dish pointing calulators and tips, hardware info, jtag info, newbie and getting started sections, actively moderated with a no troublemakers and no bashing allowed policy.. and are free, and only require a simple free registration...Your email info is kept private, unless U specify differently..and U will be notified via email of any replies to any questions U may ask (or U can shut that feature off, if U like)..and your IP is sacred and never released..
Many of these specialize in particular FTA receivers as noted next to their links..USE those for your particular receiver manufacturer..
If U want real info, trouble free, no costs, friendly help, no hassles, latest files and manuals, then use these...these are well established, and have a long history, and are the best known sites throughout the entire DSS community now...
Ecoustics is NOT a Dss site, since is has NO files, no manuals, no guides, little info, no specific categories, and is almost impossible to find anything because every thread here has been allowed to be hijacked (because no mods are active) and the Subject does not relate to the posts within it....also Ecoustics is basically an Electronics site for home audio, television, DVDs, stereo's, and things of that nature, NOT FTA satellite information .
So again I highly recommend using ANY of these sites BELOW!....U pick one and use it for fast , friendly info and files, and many of these also have a LIVE chat area what U can get an IMMEDIATE response from reliable knowlegeable sources!...U will save yourself much time, especially if you are a newbie to this hobby!...and most all also will have the latest keys posted as well, and the keymaster, keyripper, key grabber utility files to download as well....and if plastic is your thing , some also have an area for that as well as FTA..Good Luck and enjoy this hobby!
Data Viewing Sequences
[link removed]
or get Keymaster 4.0 here free and NO registration is required...
[link removed]
NOW IS THE TIME TO USE THESE SITES FOR YOUR NEEDED NEW FILES.....
BTW...Pansat has released ALL new working Globecast autoroll bins at futurefta.info and available here too ...just REMOVE the * in the link
http://www.dsscommunity.co*m/forums/viewforum.php?f=31
ENJOY!!!!
