Captive works new bin 1.39 not working??
Username: Buddho81
Post Number: 33
I just loaded the new 1.39 bin on my CW600s
Seems like its not doing the autoroll...its keep saying scrambled channel??? Anyone have any idea??? i know i can enter the keys manually but I thought AR was working with the new bin???
Thanks in advance!
Username: Brucester
Post Number: 548
you can try this do factory default then scan sat that yor dish is pointing at then exit hit f1 on the remout then 000 to inable the patch watch tv
Username: Frobi
Guelph, Ontario Canada
Post Number: 57
Bruce, I have CW 600s premium. What bin should I load, 1.39 or 1.47 ? Also will loader V1.05 work?
Thanks.
Username: Jurj1
Post Number: 218
Sheel neil, 1.47 for CW 600s premium
Username: Brucester
Post Number: 554
thanks for helping out good one
Username: Larrydumass
Stuppitville, Ark Werdufunkarewe
Post Number: 44
bruester do you know the address of where I get a cw 600 permo fix?
Username: Ellisd
Post Number: 7
w.f2atv.c....reg site
Username: Togirl
Post Number: 44
after you download the latest 1.47 bin for cw600s premium, do you have to set autoroll ON ?
thanks !
Username: Albino_midget
Post Number: 611
yes -- autoroll on.
