NIMIQ 2 - BEV
Username: Wariat
Post Number: 44
I just loaded the new BEV program to my viewsat and it worked but the Nimiq 2 satelite channels dont work, while Nimiq 1 does work.
anyone know what to do?
Username: Spank
Post Number: 327
Get an HD receiver
Username: Wariat
Post Number: 45
that does not answer the question because it was working before I changed to the new FIX today
Username: Spank
Post Number: 331
No, that probably doesn't answer your question but if you had an HD receiver you would love NIMIQ 2
Username: Hardrockstriker
Post Number: 987
Is your dish aimed correctly? Are your receiver antenna settings proper (82 deg lnb mapped to correct switch port mapped to Nimiq2)?
Username: Tapeman
New York City in-HD, NY
Post Number: 1373
Yep
Jason is right
Aiming and correct setup will get yo what is missing
However if U R using DISEqC switch can be shorted from rain etc.
These are few basic tips:
- Steady dish point and alignment
- Good shielded cables(RG-6) and sealed connectors
- Must match LNB type to receiver santenna settings
