Silver Member Username: RunnerguyPluto Post Number: 364 Registered: Sep-06 | Does RG-6 cable loose efficiency if it is used longer than 60 ft? What is a good price per ft? |
Platinum Member Username: LklivesPost Number: 10481 Registered: Jan-06 | RG6 is usually good for at least 100 ft ...its the best....price, I dunno, I forget...check at the local hardware store or Home depot maybe.. |
Bronze Member Username: Sobe1South beach, Fl Post Number: 34 Registered: Jun-07 | easiest place to get is at Home depot. i believe its $1.60 per foot |
Silver Member Username: RunnerguyPluto Post Number: 365 Registered: Sep-06 | Thanks for help....Found a 500' roll on craigslist for $10...Probably hotter than a firecracker. |
Platinum Member Username: LklivesPost Number: 10486 Registered: Jan-06 | U stole it for that price....hope U kissed them too...lol |
Bronze Member Username: Bill038Post Number: 50 Registered: Sep-06 | That's the roll that fell off my truck |
Platinum Member Username: LklivesPost Number: 10490 Registered: Jan-06 | that must have been the truck I was towing for repo......lol |
Gold Member Username: SatscannerBeaversbush, Sportsmans P... Great White ... Post Number: 2322 Registered: Nov-06 | A $1.60 a ft ! Damn I get a hundred ft roll $9.oo retail most places.But thats a good deal Zulu .Bulk wholesale price ,Plus clearance or something. |
Silver Member Username: RunnerguyPluto Post Number: 368 Registered: Sep-06 | Ended up where I got 1350 ft for $20 USD, 350 ft of it is quad shield. The guy does commercial installs and has to much stuff lying around. |
Gold Member Username: Crazy_greekPost Number: 1024 Registered: Jul-06 | At Home Depot all day long, RG-6/U Coaial Cable sells for $99.80 per 1,000 foot reel. Parts Express sells for $72.88 per 1,000 foot reel. http://www.partsexpress.com |
Silver Member Username: TherepoFtaview.com Post Number: 137 Registered: May-07 | You got a dealio, zulu! I usually pay around $50 CAD plus tax/ship for 1000 ft. For long runs, yes, the longer you go the more loss, but just as important as length is the quality of the cable--dual/tri/quad shield and % braid, and you'll see "swept to X Ghz", but it's not always all practically meaningful. When in doubt, choose a good brand. Belden is an excellent cable choice. I have about a 150' run to diseqc, and on two LNBs there is about another 20' after that. Using Legacy LNBs, and no problems. (Although I wouldn't use a Legacy twin at that range, the SW voltage pulse wouldn't make it for switching). |
