Factory flash then add new keys
Username: Yarde
can you do a factory reset then set up sat then manually enter new keys for Pansat 2500A? Also when you go to Nagra 2 0101, should you enter new keys on key 00 or 01? not sure with this second field. Thanks
Username: Runnerguy
Pluto
Post Number: 329
Put in 00 keys, then go back up to 00 and arrow to the right, 01 appears and enter those keys. But if you just put in the 239bin it will roll for you. I have been keeping both autoroll off and autoupdate off and it still rolls.
Username: Runnerguy
Pluto
Post Number: 330
Yarde...You are posting similar question on C/C with added criteria: "I don't have a cable to flash bin" If this is the case your not watching TV!!
