148 in Ontario
Username: Farooq1371
Wanted to know if I can get 148 in Ontario,Canada
thanks for response
Username: Lklives
Post Number: 10103
Satellite Finders (Look Angle Calculators)
[link removed]
http://www.hollsco.com/Products/SatCalc/
http://www3.telus.net/rampage/skew.htm (Dish 500 support)
http://www.remotesat.com/lookangle.htm
Username: Therepo
Ftaview.com
Post Number: 74
No jija, you'd be pointing almost at the ground. 148 can be seen from the West coast. If you're interested in that programming, try aiming for 61.5 Echo 3, it has basically the same.
Username: Edenman
Post Number: 418
yes, you can get it, and yes, it looks like the dish is pointed at the ground lol You need a GOOD west view, its very low to the horizon
Username: Crazy_greek
Post Number: 968
If you live West of Ontario you may have a slim shot.Elevation from Thunder Bay is 11.7 degrees,
from Kenora is 14.1 degrees.
Elevation East of Ontario is below 6 degrees.
I would think that you will be wasting time and money.
I would do as therepo above suggested.
Username: Edenman
Post Number: 419
Here in Toronto, dishes pointing west and at the ground are everywhere. I have one lol Its possible, you just need a good view.
