Viewsat Platinum Dead
Username: Lbinny1
Post Number: 35
I haven't been able to pick up any channels for awhile and tried to factory default and installed the factory bin and then the new program (070421p). I edited the satellite settings and put them to what they were originally when it did work. I scanned sats and nothing. I tried factory default again and tried putting the oldern bin (070407p). Nothing. Now it decided to die. This morning it read "inst" for some reason and then it went black and won't turn on. Is there anything that can be done to revive it? Or am I just screwed and I need to purchase a new box? Thanks.
Username: Senators
Post Number: 115
totalfta.com
go their and try a factor bin and check the help section
Username: Hawaiian_time
Kanaka freak...
Post Number: 1115
Try turning it off in the back for a few seconds before anything else.
