Cool*at4000 with 4 ceros only 0000 any idea
Username: Tetio2004
Post Number: 34
hi I did a factory reset because it was reseting by itself. Now my cool*at 4000 is not working It is locked and I olny see 0000 and it won't work
any ideas please!!! somebody
I will appreciate so much plase!!! please!!!!
Username: Albino_midget
Post Number: 509
after a factory reset, you have to do the antenna setup and rescan your sats.
Username: Tetio2004
Post Number: 36
thanks what happened was that after I did the fact reset I did what what U R suggesting, but when I was doing the channel scan It just rebooted by itself and since then i can not do anything I tried to go to menu It just restarted and it keeps doing it I do not know how to make it let me go into the menu. any other suggestion
thanks
Username: Lklives
Post Number: 9347
did u upload the factory bin after the factory reset/default?...if not, then u need to...and do as albino says , and rescan the sats
Username: Tetio2004
Post Number: 37
thanks so much guys
this is how itis, I switch it on, I see 4 ceros 0000, I try to go into the menu then a cero comes on then it restarts.I tried going back to 1.42bin then I put back the 1.34 bin but still no luck
where can the factory bin? is it the same 1.43?
thanks so much
Username: Tetio2004
Post Number: 38
I tried to say the 1.43bin
Username: Lklives
Post Number: 9353
Factory bin...17 Jan 2005
COOLSAT4000_120_20050117.zip
and pro loader 2.4
[link removed]
Username: Tetio2004
Post Number: 39
Thanks guys so much, LK you just made my day did uploaded the factory bin as you suggested and i went back to the 1.42 bin I found out that the 1.43 bin has a reboot ploblem. so I went to the 1.42 bin and new keys. I am now doing the auto scan. I think I will be ok thanks to you
thanks again
Username: Lklives
Post Number: 9355
congrats...perserverance pays off...U should use that site (f2atv) always for your coo*lsat..
143b is latest bin..
