Conaxsat Duo
Username: Jameslee
Post Number: 18
Conaxsat Duo
Conaxsat Duo is one of the very best in free to air satellite receivers. Conaxsat Duo is a hassle free receiver with 1 year Warranty on Everything. Great program guide, quality picture and sound. Instant out of the box USB PVR. Conaxsat Duo will only bring you the best for your Free to air needs. Many new upgrades and features will be added to Conaxsat Duo in the near future. Conaxsat Duo is loved because it can be used for PVR features it can tape and recorder all the free to air shows. You can also use the conaxsat duo usb thumb drive for bin file software support. This is a powerful yet very easy to use receiver.
http://www.conaxsatfta.com/Conaxsat-Duo-CNXDUO.html
Conaxsat Duo Features:
- Personal Video Recorder (PVR) Ready via USB 2.0
- Reserve Recording in EPG Mode
- Recorded file play on PC
- Upgrade Software & Update Channel Database through USB 2.0 Port
and RS232
- Two USB 2.0 Host for USB Storage Devices (e.g. External HDD, USB Memory, etc)
- MP3/JPEG File Store and Play via USB 2.0
- Vacuum Fluorescent Display (VFD) Type of Front Panel Display
- MPEG-II Digital & Fully DVB Compliant.
- C/KU band control for each antenna
- LNB Tone Switch 22KHz mode on/off'- Multi-LNB controlled by DiSEqC 1.0, 1.2 and USALS'- Total 5,000 Channels Programmable
- Blind Scan
- Closed Caption Support
- Parental Lock
- PAL/NTSC automatic conversion
- Picture In Graphic (PIG)'- Teletext and subtitle directly from the On-screen Display (OSD)
- Electronic Program Guide (EPG) for On Screen Channel Information
- Zoom Function by 2x.....4x
- Game function with Stereo Sound
- Dolby Digital Bitstream Out through S/PDIF
- CVBS Video & Audio Output via RCA
- Component Y/Pb/Pr Output via RCA
- S-Video Output
- Universal Remote Control
- Multi-language supported for Menu and OSD
- Built-in Smart Card Reader
Conaxsat Duo Specifications:
Conditional Access Interface
- SMART CARD 1 Slot: ISO 7816, GSM11.11 and EMV (payment systems) compatibility
Conaxsat Duo Tuner & Channel
- Type 1 ? F Type, IEC169-24, Female
- Frequency Range 950MHz to 2150MHz
- RF Impedance 75 Ohm unbanlanced
- Signal Level -90 to -20 dBm
- LNB Power 13.5/18.5Vdc +/- 5%, 0.5Amax, Overload Protected
- 22KHz Tone Frequency : 22KHz +/- 2KHz, 0.6Vpp +/- 0.2V
- DiSEqC Control Version1.0, 1.2, Tone burst A/B
- Demodulation QPSK
- Input Symbol Rate 2~45 Ms/s, SCPC/MCPC
- FEC Decoder Convolution Code Rate 1/2, 2/3, 3/4, 5/6 and 7/8
With Constraint Length K = 7
Conaxsat Duo System & Memory
- Main Processor 32-bit ARM946 RISC Processor
- Flash Memory 4 Mbytes
- System Memory 32 Mbytes
- Channel Capacity Digital Channel: 5,000
- Front VFD Display (3 Icon, 5 digit Alphanumeric)
Conaxsat CNX-Duo MPEG Transport Stream & A/V Decoding
- Transport Stream MPEG-2 ISO/IEC 13818 Transport Stream Specification
- Profile Level MPEG-2 http://www.conaxsatfta.com/Conaxsat-Duo-CNXDUO.html
Username: Jameslee
Post Number: 19
Conaxsat Duo is here!! Contact your dealers for the conaxsat duo fta satellite receiver today. powerful yet lower cost receiver.
