Pansat 2500 a (clone)))))))))))))
Username: Tommy144
Post Number: 29
Please help
I have pansat 2500 clone just by mistake I put new bin X-85BL_070411_293 which is not for clone and now just showing black screen how can I put back the 293t bin on it I try itmany time is not working please if any one know help me thanks.
Username: Viruscauser
Leesburg, Georgia
Post Number: 73
Try a Jtagless Fix. Should get you back up and running.
http://www.dsstester(dot)com/files.php?cat=14
Username: Tommy144
Post Number: 30
thanks Abby for your help this site is down and also I dont know how to Jtagless cany u tell me plz....
Leesburg, Georgia
Post Number: 74
The site is down because it's overloaded but keep trying and you will get through. I don't know how to Jtag either but the Jtagless Fix is easy.
It's just like loading a Bin but there's a special file and a set of procedures you have to follow. It's all been laid out well at that site. You'll see.
Don't worry. It's so easy to do, even a Caveman can do it. LOL. Just keep trying to get through to the site.
Good luck.
