NO SIGNAL OR QUALITY
Username: Sgt_cobra
New York, N.Y. Kings
Post Number: 12
My dish is bolted down, all connectors are good. all setting are correct. What the hell gives....
Username: Hawaiian_time
Kanaka freak...
Post Number: 970
Was it working before it went down? Or are you setting it up for the first time? What receiver do you have?
Username: Sgt_cobra
Post Number: 13
it's been up for 6 months, dish is bolted.
using a viewsat extreme
Kanaka freak...
Post Number: 971
Try flashing with factory file then newest file.
