What are The DV channels?
Username: Thadragun
Kingston, Ontario
Post Number: 11
I was curious what are the DV channels on BEV? (eg COMDV)There's a bunch of them and on some of the channels I see the picture, but don't hear any sound. While others are normal and I can see picture and hear sound. I thought they might be high def or something but if that was the case I wouldnt be able to see the picture. Is there special equipment I need to hear them? There's some good shows on those channels sometimes..
Username: Ke5aqn
Post Number: 875
They are "copy's" of other channels usually with special audio to help def or blind people. I played with a few of them with no luck at getting the sound I assume you would have to be a subscriber with the correct receiver to receive the channels as they are intended. I delete them as they are the same as other channels anyway.....With 900 or so channels I feel you should be able to find something to watch I hope this helps....
Username: Thadragun
Kingston, Ontario
Post Number: 12
Oh ic. I guess its nothing to worry too much about. I'm sure I'll find the duplicates.
lol not 900 yet. I'm working on it tho. 280 or so right now.
Thanks for the reply.
