Satellite Finder SF3000
Username: Konikgarbusek
Post Number: 12
Has anyone tried SF3000? Need your opinion. Thanks,
Username: Brucester
Post Number: 371
i have the sf-20 and i find my sats with no problums min cost 20 dollers can but did not try that one
Username: Cartier1
Post Number: 217
sf3000 is very expensive . if u have to buy it then i suggest not, but if you get it free then it's great .
this is what you should buy in my opinion . this what i use , very easy . accurate .
the cost is around 435 dollars (usa dollars )Upload
Username: Brucester
Post Number: 374
that is nice but for that price cw got it bilt in sat finder in the cw600p for 110 and works good if you got 2 pepole its eazy one looks at tv and reads the sat as you get closer and tells you witch sat you are at
