Plz japan programs dont tell me to go to lyngsat :-)
Username: Cartier1
Post Number: 206
guys i know there is japan tv in echo3 61.5 is there any other japaneese channel i can get . what sat is that? thanx . i will reallyyy really appreciat your answers. the one who help will get a gift surprise from cartier .
Username: Crazy_greek
Post Number: 758
Hey CARTIER
I don't need your gift.
Here are two give-mes.
AMC-16 @ 118.75 (TPs1&23)
Channels 698 & 710 (enjoy)
Username: Ryersonresurrected
CANADA Charlatan...
Post Number: 1011
CARTIER try lyngsat. com
Username: Cartier1
Post Number: 209
kavin you are darling . so the dish has to be 33" and the lnb is ku linear. ? if it is what the elvation.? thanxxx
ryerson you can answer if u know about fta . becuz i haven't heard from your expertise
Post Number: 764
Hey CARTIER
Your Dish is OK.
LNB has to be a Circular.
Your Elevation Angle should be the same as
EchoStar 7 @ 119.oW.
CANADA Charlatan...
Post Number: 1014
Cartier, i will help u .... ur dish is fine, but don't forget the LNB has 2 be a circular one.
And make sure that ur 'elevation angle' is the same as Echostar 7 - 119.W
Ok?
No thanks is necessary, no probs at all.
