T with viewdPRFRMNJ about dpp reselt
Username: Cartier1
Post Number: 126
we made lnb dpp work great with viewsat for one day and then we lost signal. we keep turning on / off the reciever no luck . and then suddenly the pic comes for couple hours and then the signal gonneeeeeeeeeee. dpp is still giving lot of headack to poeple.
Username: Prfrmnj
Post Number: 2205
That's why I said that DishProPlus is a headache to make work. The best is to use the regular old DishPro Twins or Quads. The problem with DPP is the voltage...
Username: Cartier1
Post Number: 127
yeah thanx for responding . i just wanna update you with experiment s we try . especialy now diosh network is using only dpp lnb's for gettying better quality picture.
so long .
