Digiwave 7200 S Loader
Username: Dure
Mississauga, Ontario Canada
Post Number: 48
What is the uploader for Digiwave 7200 S. Some body pl. answer. Thanks
Username: Banti
Post Number: 29
i think its called ftlink or something dont know i need help myself on digiwave
Username: Brucester
Post Number: 346
Digiwave Loader - FTLINK V3.4
Username: Banti
Post Number: 31
when i load digiwave to computer and downlaod ftlink then it says connection fail and it also says UNAilable
Username: Brucester
Post Number: 347
what cable are you using the 1 you need is stright through cable
Username: Saw_tech_one
Post Number: 17
Banti u need to use null cable and make sure what port u using com1 or com2 it's always com1 here is the last date of that bin is nov 19 and use the load that Bruce told u to use.
Username: Brucester
Post Number: 348
mike is right the one i read is for the dg dimond sorry for the bad info thanks for catching that mike
Post Number: 18
any time Bruce it happends
