Pansat 3500SD - 312 bin
Username: Dish_newb
Post Number: 22
First off - sorry if I am starting a new thread for something that is already addressed elsewhere. If thats the case, please point me to the link.
If not - has anyone tried the new 312 bin for the Pansat 3500? I am unable to flash it using the SD card? Has anyone had any success? Is there a solution to this issue?
Username: Pungi
Post Number: 25
use null modem cable for loading this bin.
Username: Lroy
Post Number: 171
Yes, you should use null modem cable, load boot file B-80 first then load the 312 bin, scan or load your channel list and you should be ok.
application/x-zip-compressedUpload
boot file b-80.zip (7.6 k)
Username: Ganjaman
Post Number: 39
Strange. I flashed the 312 bin from the SD card with no problems.
