Adding channel manually in pansat 2700A
Username: Aksma
Post Number: 37
Hi
Can somebody please help me in adding a channel in Pansat2700A manually. How many times I do satellite scan, the channel 457 and 471 is not being scaned. I have these settings, how do I add those..
defre:13362
SR:20.000
echo 110
Any help is appreciated.
Thanks
Username: Ke5aqn
Shawnee, OK USA
Post Number: 414
whats the channel name?
Did you do a blind scan?
Username: Crazy_greek
Post Number: 456
Hey Achsah
Channel 457 is on EchoStar 8/10
at 110.oW PPv Sports Freq. 12239 (Pol.H)
SR 20,000 (tp2) also on the same TP,
Dish Network PPv Channel 517.
There is also a PPv Sports Channel 461
at EchoStar 8/10 Freq. 12443 (Pol.H)
SR 20,000 (tp16). I couldn't find Channel 471
or Freq. 13362 on EchoStar 8/10.
Channel 471 PPv Sports is located at
EchoStar 1/2 @ 148.oW. Just do a TP Scan
for the above TPs.
Username: Prfrmnj
Post Number: 1514
As pointed out by Kevin above - Do a TP Scan of those transponders and you will get those channels. In the event you are not getting a signal from there, you will need to verify the alignment of your antena.
Username: Aksma
Post Number: 38
Thank you all Very much! I will do those tests and come back... :-)
Achsah
Username: Skypatel
Post Number: 27
Hi
I am having the same problem. I did all kind of scan, but I am not getting channel 457 and 471.
Achsah...let me know if you are getting the channel? and what exactly you did to get those channels. Please post step by step instructoin as I am new to this.
Thanks
Username: Prfrmnj
Post Number: 1520
Patel - follow the same instructions given above. I'm not home so I can't tell you if the channels have changed location.
Username: Ke5aqn
Shawnee, OK USA
Post Number: 423
those channels are working...well nothing on today just the dish PPV PPV screen but, working
Username: Skypatel
Post Number: 30
Jay
What bin are you using on your 2700A receiver?
Username: Ke5aqn
Shawnee, OK USA
Post Number: 436
Sky,
I have a 3500 and a pansat
go to http://www.future-fta.info/Forums/ find the section for your receiver and get the latest .bin for your receiver. That is the home for pansat the people that make the bin files are their all other sites have copy's of it. Its always best to go straight to the source.
Username: Skypatel
Post Number: 31
I am still not getting channels 457 and 471. I did the blind scan and I also changed the keys. I am on satelite 110. It's still not working. Any help is appreciated.
Username: Ke5aqn
Shawnee, OK USA
Post Number: 447
they are working
by working I mean just a red screen with the dish network logo on them NO PROGRAMING
you need to be sure you are on the right bird, and your antenna settings are correct.
Username: Skypatel
Post Number: 32
Antenna settings are correct because this was professionlly installed bY dish network people. Do I need to change the DiSEqC or TP on the antenna set-up screen?
Username: Skypatel
Post Number: 33
Do you also get Asian channels, such as Zee tv, TV Asia, etc? I don't get these channels.
Username: Skypatel
Post Number: 34
Its working now.
Thanks
