Trying to get dn
Username: Jamie1234
Toronto, Ont Canada
Hi
right now I have all channels on bev, now I want to
get dn also. Not sure where to point,do I need two lnb one at 110 and one at 119.
And can I have both, In closing I want to pick up dn, any advice would be greatly appreciated
Username: Ke5aqn
Shawnee, OK USA
Post Number: 326
Best advice I can give you at this point is to read. Their is a good post here with Reputable Dss sites (Satellite forums)that has a great forum list. On most of these forum's you will fund a section dedicated to how to get DN.
Hope that helps let us know
Username: Eatfish111
Post Number: 73
you can get bev and dn with same dish but need 3 lnbs. DN id sat 110 and 119w or echo 7 and echo 6.8. Dishcumbia pointer is a program that has helped me many time when I point dishes.
It can be found at fsfta.com and ftamorvex.com
fsfta.com has alot more info about pointing a dish and getting dn
Also try lyngsat
http://www.lyngsat'com/
Username: Ftalife4
Post Number: 8
The best dish to pick up is a dishpro dish 500, this will allow you to get both the 119 and 110 sattelites, and is fairly easy to set up. Using a multiswitch, you connect with your bev and you have all three.
Hope this helps.
