How do u load a bin using a USB
Username: Shab62
Toronto Canada
Post Number: 28
Hi i have fortec classic NA receiver and need to load a new bin file on to it. i have a new computer so i dosnt come with rs232 port so i am using usb to rs232 port to connect but my loader dosnt pick up any signal. can any one please tell me how to load a bin file using a usb port
Username: Ke5aqn
Shawnee, OK USA
Post Number: 253
most have alot of trouble trying to do that. I would suggest you find a older computer withe the correct port and use it. That being said their have been several threads on this on this forum I will now try to find them and put links here.
Username: Shab62
Toronto Canada
Post Number: 29
Ok thanks.
Username: Ke5aqn
Shawnee, OK USA
Post Number: 254
https://www.ecoustics.com/electronics/forum/home-video/288469.html
https://www.ecoustics.com/electronics/forum/home-video/311516.html
https://www.ecoustics.com/electronics/forum/home-video/187236.html
Username: Ke5aqn
Shawnee, OK USA
Post Number: 255
I still go back to go find a cheap mabee free older computer and use it just for this purpose. I use a older dell laptop that was on eba$y for $200. I got it home and loaded it with win 2000 and it works great..Its easer to take the laptop to the receiver without having to dig it out of its home, bring it over here to main computer, load bin's, take it back...now i just take the laptop to the receiver the serial cable is right their already for me easy as pie...
Username: Shab62
Toronto Canada
Post Number: 30
Nice advice i will look up laptops. and 1 more thing. i heard that the new extreme sat are coming with the built in usb port. is it true
Username: Ke5aqn
Shawnee, OK USA
Post Number: 257
Its the viewsat ultra here is a page all about it.
Please understand I am not advertising for the retailer just giving you a link to a page with info. Always be thrifty and shop around eb*ay is a great place to shop!
I am a great fan of the viewsat so i want one now LoL I have the Platuim
Username: Lklives
Post Number: 7071
Thread: How to load a VS Ultra...USB stick or cable
LK
Username: Lklives
Post Number: 7002
Posted on Tuesday, January 09, 2007 - 01:25 pm:
Viewsat 2000 Ultra Setup Guide Using Serial Cable (NULL)/USB
A. Loading your BIN using Null cable:
· Connect serial cable (NULL) to PC>STB
· Open up Loader of choice (PVR-Loader 1.1 or Loader2)
· Click on Tool>Configuration>Com port (Default is com 1)
· Click on Open File
· Click on PC>STB (Notice the progression bar in loader)
· Turn the power in the back ON
· Wait for Loader say Completed. Then on box LCD front panel screen say I.N.S.T>END>0000 or until clock count to 0.001
IT IS VERRY IMPORTANT. DO NOT TURN THE POWER OFF TO SOON
· Turn the power OFF in front and power OFF in back
· After downloading the "BIN", unhook NULL cable from PC>STB
· Connect all the cables to your box/TV
· Turn the power ON in the front and back
· Press Menu key
· Select Installation and press OK
· Select Antenna Setup and press OK
· Select your Sat.
· Here if you have a DISEqC switch enter the port #, Motor or Legacy SW
· No LNB Type need to select (from new, you have only two selection Standard and Universal). STB will select your LNB Automatic
· Press Exit and select Yes for saving the settings
· Your back to Antenna Setup screen
· Here you have Three choices:
1. Channel Scan
2. Auto Scan
3. Blind Scan
· Select Auto Scan
· Press OK
· You are in the Auto Scan window and you see the Bird(Sat.) you selected and on the top of your screen are three options:
1. Search option
2. Network search
3. Scan Start
· You don't change nothing here, go down and select Scan Start and press OK
· You do this for all the Birds (Sat.) you have
· Wait for Autoroll and watch TV
B. Loading your BIN using USB Jump Drive
· Turn the power ON from the front and back switch
· Press Menu key
· Select your Sat.
1. Channel Scan
2. Auto Scan
3. Blind Scan
· Select Auto Scan
· Press OK
1. Search option
2. Network search
3. Scan Start
· You don't change nothing, go down and select Scan Start and press OK
· Now its time to download your BIN ( Newest autoroll bin http://www.totalfta.com/forumdisplay.php?f=153 )
· Insert the Memory Stick in your PC and transfer the bin in. Than insert in your STB and in the Main Menu select System information and press OK
· Select Receiver Upgrade and press OK
· Go down to the bottom of the window, select USB and press OK
· A new window opens with some Korean files, years, etc.
· In the bottom of the window, it is your bin selects and presses OK
VERY IMPORTANT. DO NOT TURN THE POWER OFF
· After you load the bin, the STB will reboot automatic
