Signal Problems
Username: Sniper66
Post Number: 29
im getting perfect signals for 148 and 110...but for some reason im getting nothing for 119...the wires and everything is connected and..fine..but im still having this problem..and its happend before..any know what to do?
Username: Nikk
Post Number: 856
check for humidity in the Diseqc.........
Username: Leafs_fan_4_eva
Post Number: 192
yeah same im getting the same problem for 119 and 61.5. There's no signal and none of the channels are coming. I have a viewsat extreme.
Username: Sniper66
Post Number: 30
do i need to change the numbers or sumthin
Username: Geeker
K- Town!!, OnTaRiO! CaNaDa
Post Number: 214
Yes it is only a code change
Username: Sniper66
Post Number: 32
it has nothing to do with the code...because my other channels are working fine...its just 119..and the 119 signal...
Username: Bones714
SO.California
Post Number: 181
how do u have ur diseqc setup?
Username: Sniper66
Post Number: 33
yeah..the diseqc is fine
Username: Bones714
SO.California
Post Number: 184
sniper, I have the same problem but it only happens to my 110. what i do is play around with the 110 channels, find one that works then all should work.
I use a local channel on 110, works 90%
Username: Heyhowru2004
Post Number: 35
i had the same problem last night...turn off power...unplug all the wires from reciever and tv...wait 5 minutes...plug wires back in...turn on reciever...u should now get back the signals...it worked for me
Username: Skz720
Post Number: 21
I have a pansat 2700A and I'm getting a "No Signal" sign, what do I do?
Username: Sniper66
Post Number: 34
thnx man...it worked
Username: Prfrmnj
Post Number: 1218
KZ - what's the setup? Where are you located? Are you running a Switch? Basically tell us everythign about your system and location.
