Weird. O.o
Username: Tahdah
Hey my satellite is working just fine and i can watch the channels just fine, but for some reason when ever i watch a channel there's this black thing that covers most of the screen. i can't see anything. does anyone know what the problem might be?
i own a p*nsat 2700
Username: Tahdah
help me please it' very annoying to only be able to watch like half of my screen.
Username: Juancho
Superior Lake, Nothwestern ... Canada
Post Number: 328
Blah blah, You need a new TV or used one but a little better than your. serious check up reciver's back panel channel 3 or 4, or your TV cables.
Username: Tahdah
i already checked that. all the local channels look fine and nothings wrong. it all started right after i put in the new keys. when i access the menu of my p*nsat it looks fine. they only time there is a black thing on my screen is when i try to watch channels. also my tv is quite new. its only around 2 yrs old.
Username: Satscanner
Beaversbush, Sportsmans P... Great White ...
Post Number: 714
You have black list on your screen.Bl is very annoying,Go to menu,bl/delete,then exit,exit.
Username: Poser
FTAPlayGround.NETFTAPlayGroun...
Post Number: 106
LMAO, I 'm sure reputable faces in this community can help you, they have helped everyone,
might i suggest try getting a haircut if ur hair is in ur face, LOL
Username: Tahdah
my hair isn't in my face. -_-. bl on my screen?
Post Number: 721
Yup! BL happens to the best of us at one time or another.
Post Number: 722
All pansats and clones are plauged with BL problems,there is no cure for BL problems other than a different make of receiver .
Username: Ke5aqn
Shawnee, OK USA
Post Number: 193
I am thinking the trouble is not BL its BS on his TV..
if you do have a black screen i would do a factory reset get the latest bin and rescan everything.
Username: Crazy_greek
Post Number: 372
Hey blah
I think it's your TV settings not your receiver.
Try this,disconnect your satellite receiver.
Connect a set of Rabbit Ears to your TV or
long piece of coaxial cable, now pull up your
menu on your TV & check your Parental Control Settings.
Username: Prfrmnj
Post Number: 1195
I had that happen with a tv I had. It's the TV itself. You can try to either connect your STB using either the S-Video, RCA or Coax. You'll need to see which one works. But it is the tv and it's the parental controls.
Username: Prfrmnj
Post Number: 1196
Kevin - sorry I just repeated you. Didn't see your post before
Post Number: 373
PR
I did the same thing the other day.
No sweat.Iam glad that you too, could help.
Username: Tahdah
Post Number: 7
yea i hooked up rabbit ears and everything works fine. i even tried dvd and vdr( old skool ). the only time this happens is when i use th e box. one guys said that i need to get a new box whereas another person said that i can delete the bl. i don't see it anywhere on my screen tho.
Username: Prfrmnj
Post Number: 1210
Blah blah - If you have another TV you can try this with or borrow one then hook the box up before you start tinkering with the box. Make sure it is the box and not somethign else.
