Viewsat 2000 ultra
Username: Toto132
Post Number: 14
I just bought ultra download the new bin. Works fine only problem i have the time is wrong i went to menu user setting-time setting i changed it i go back to guide time is still wrong can some one help me fix it?
Username: Mc_sunny
Post Number: 952
Rather then setting the time manually, use Auto, and set it correctly for your Time Zone.
-5:00 for Eastern, -8:00 for Pacific. Once set, turn it off and back on again using the switch in the back and see if that helps.
Username: Toto132
Post Number: 15
thanks alot MC sunny it worked
Username: Mc_sunny
Post Number: 953
ur welcome, now enjoy ur viewsat !!
