CAPTIVEWORKS HELP
Username: Da_one
Post Number: 13
I WOULD LIKE TO KNOW IF THERE IS A BIN THAT I CAN USE TO PUT A CAPTIVEWORKS CW-600S.
IT HAS BEEN LIKE TWO MONTHS THAT I HAVE NOT USED IT.
THANKS.
Username: Destine1983
Montreal, Quebec Canada
Post Number: 185
A good place to look for a bin for your box is in www.dssevolution@com
type into your search bar and replace the @ with .
Username: Sstwired
Post Number: 7
Flash CW 600s
I Load CW600SV 1.27_autorollfix.
Connect your PC and receiver with twisted RS-232C Null modem cable.
Turn on the receiver you will see 00:00 and then press "POWER" key on front of the receiver panel to make it standby, the LED dot - - : - - will blink.
Note: Loader will not work until you see - - : - - on LED panel
Run the LoaderV1.06P on your PC. Select the right COM port where you connected your null modem cable usually COM1, then select
<download>, press <open> and select the above bin file, then click <start>, upgrade will begin.
After finishing, the LED will display "-End"
Exit all menus, Press F1 key; the LED will display 'H', then press '000' to enable patch.
Watch TV
