Chase, can't help 100% with Bev, I had not time to install it. But this should help: 1) Press: 'Menu' 2) Select '5-Options' 3) Change 'Auto Roll' from 'On' to 'Off' 4) Press 'Exit' 5) Select '3-Installation' (If asked to enter pin try '0000', this is the default pin) 6) Select '7-Code' 7) Select '3-Nagra' 8) Press the Left arrow until You see DISH 01 01 00 - next one would be "BEV" I am not sure, but there maybe 2 "Bev"s (There to "Dish"s), make sure you are in the right one.
9) Press the down arrow to edit the Keys (1st line-00 is not part of the keys-this applies to "Dish"). Key Numbers-16 Pairs of numbers. "A/B/C/D"="F1/F2/F3/F4" For entering Keys "E" = "return" (Above the + Button). "F" button is the "Text" or "Color" button. Cheers
