Pansat 3500 SD Set Up
Username: Cabrunet
Hi, I just received a DishNetwork dish and a pansat 3500sd. I want to set this up and have no idea where to start. I understand I need software, but cant see to find it for free. Can anyone give a novice (non technical) person a hand? Thanks.
Username: Lklives
Post Number: 6928
U looked real hard....LOL
Thread: Reputable Dss sites (Satellite forums)
LK
Username: Lklives
Post Number: 6817
Posted on Wednesday, January 03, 2007 - 10:25 am:
All these sites ALWAYS have the latest files, bins, how to's, manuals, guides, dish pointing calulators and tips, hardware info, jtag info, newbie and getting started sections, actively moderated with a no troublemakers and no bashing allowed policy.. and are free, and only require a simple free registration...Your email info is kept private, unless U specify differently..and U will be notified via email of any replies to any questions U may ask (or U can shut that feature off, if U like)..and your IP is sacred and never released..
Some of these specialize in particular FTA receivers as noted next to their links..
If U want real info, trouble free, no costs, friendly help, no hassles, latest files and manuals, then use these...these are well established, and have a long history, and are the best known sites throughout the entire DSS community for many years now...
Ecoustics is NOT a Dss site, since is has NO files, no manuals, no guides, little info, no specific categories, and is almost impossible to find anything because every thread here has been allowed to be hijacked (because no mods are active) and the Subject does not relate to the posts within it....also Ecoustics is basically an Electronics site for home audio, television, DVDs, stereo's, and things of that nature, NOT FTA satellite information
So again I highly recommend using ANY of these sites in this first post!....U pick one and use it for fast , friendly info and files, and many of these also have a LIVE chat area what U can get an IMMEDIATE response from a reliable knowlegeable sources!...U will save yourself much time, especially if you are a newbie to this hobby!...and most all also will have the latest keys posted as well, and the keymaster, keyripper, key grabber utility files to download as well....and if plastic is your thing , some also have an area for that as well as FTA..Good Luck and enjoy this hobby!
Final Solution Free To Air:
[link removed] (C00LSAT and All receivers)
DSS Newbies:
[link removed] (Pantecs,all clones and all receivers)
[link removed]
Username: Cabrunet
Thank you for all this info. I went to a few sites, and registered, but none will allow me to download. I think an adminstrator needs to allow me, and that's not happening. I did get confirmation emails back, but not able to get in.
Btw, the Blacklists site isn't working.
Thanks again, I appreciate the time.
Username: Lklives
Post Number: 6942
try www.totalfta.com ...they are usually available
Username: Poser
FTAPlayGround.NETFTAPlayGroun...
Post Number: 91
try www.ftaplayground.net, they got all latest files and they are very newbie friendly, they'll help you setup ur box,
Good luck,
Username: Lklives
Post Number: 6951
U are the biggest spammer here!...any site that needs to do that can NOT be too REPUTABLE!
BTW...I am NOT associated with totalfta!...and obviously U are with palyground since its in EVERY post of yours!...I hate spammers!...they usually are scammers too!
Username: Lksuxit
Post Number: 90
http://www.ftamorvex.com
How's that LK? Not as bad as your spam list, but I'm sure you will call it spam anyway. People don't go to the sites you list because you list it too much, it's worse than spam, you are trying to brainwash them into your point of view. A warped point at that. Nobody likes you, you have a couple of azz kissers and a couple of newbs who hang on your every word. That and your other nicks, so dumb.
Username: Cabrunet
While this banter is amusing, it's of no assistance to me. Thanks.
Username: Lklives
Post Number: 7025
rosa...all U do is reply back to the site with the link provided in the confirmation email...use your username and password to login...its very simple...all sites work and have the same simple procedures..
