Viewsat xtreme
Username: Oglejust
Il Us
Post Number: 219
i just got my viewsat xtreme today and i dont know how to program in the new bin file. i got the bin file i just dont know how to download it. i have a pansat 2700 and it has a loader does viewsat? how do u load the bin file in? thanks
Username: Oglejust
Il Us
Post Number: 220
help please!!!
Username: Ganjaman
Post Number: 23
download the loader for your viewsat at www dsscentral "dot" net
Username: Rekman
CANADA
Post Number: 84
lol @ ganjaman !!!... u Bcome Ganja coz of Dishnet ??... lolzzz
Username: Whitford
Post Number: 13
Is the viewsat extreme better or the platinum? I'm looking for advice on what to buy....
Username: Hshakarchi
Post Number: 63
Got this from some dealer link...
Viewsat Xtreme has all of the same features and technical specs as the Platinum plus TRUE HARDWARE BLINDSCAN and COMPONENT VIDEO OUTPUTS!
Username: Whitford
Post Number: 16
Could someone post the exact names of the loader file , and the bin file for Viewsat Xtreme? I want to make sure I use the latest working files.
Username: Pukka
Post Number: 72
as ganjaman posted if you go to dsscentral, files for vs will show loader 2 the one you need and wont show files that belong to another receivers
Username: Whitford
Post Number: 18
I found the Loader2 program, and in the tutorials there is a mention of the PGM file which I found also. What are the opkey hex, chaninfo and satinfo files? I've found some opkey hex files on dsstester but am not sure what file I need for an xtreme. I thought I would only need the bin (PGM file) -- what is the purpose of the other files?
Username: Minn_rock
Post Number: 433
Don Whitford ..
VS Xtreme B1 AR fix (10/07/06)
http://www.dssrookie.com/forums/
Username: Filetester
Deep down, Up there Canada
Post Number: 9
these are good instructions by FTAVIP:
NO CHANNEL LIST "EASY" Setup for ViewSat 2000 PLATINUM
WARNING: Do NOT Plug or UN-Plug VIEWSAT Into Wall Socket UNTIL Told - ViewSat damage may occur !!!
WARNING: Do NOT Hookup DiSEqC switch with Viewsat Powered !! Will Damage Switch
Assumptions: The "Easy" setup assumes: you are converting an existing installation; that you already have a satellite dish installed; that the satellite dish is aimed to the 119 and/or 110 orbital position(s); that you are using Legacy LNBs.
Basic Things You Need (Check the boxes as you go)
[]a []b []c 1a. ViewSat2000 Platinum 1b. DiSEqC switch 1c. Null Modem Cable
 2. Computer with a Serial Comm Port
 3. Television set (Tune TV to either Channel 3 or 4--Same Channel as ViewSat STB output is set)
[] 4. Satellite dish & 1 or 2 LEGACY LNB(s). Hook LNB cable(s) to DiSEqC [Port 1 to 119; (E*7) Port 2 to 110 = (E*6,8)]
With 1 LNB: hook directly to ViewSat without the switch OR through the DiSEqC switch. Your choice.
With 2 LNB: hook 119 cable to switch Port 1; hook 110 cable to switch Port 2
[] 5. Files: "ViewsatUSA_V69.PGM" (various names, but will have "V69" in name with a ".pgm" file extension.Get the new pgm from here: [link removed]
Unzip Zip file.
[] 6. (Most important!) Use your "common" sense!
 1. UNPLUG ViewSat. Connect ViewSat to computer Com1 Port with Null Modem cable. (Reboot computer, if needed)
 2. Open the program "Loader2". Get here: [link removed] UNZIP.
[] 3. Click "Open Files", select "ViewsatUSA_V69.PGM" to flash to STB.
 4. Click PC->STB, then Plug In your ViewSat electric power. (You should see the File loading properly)
[] 5. It's finished when STB displays "End", then "0000". *** WAIT for ViewSat to display "0001" on the front display.
[] 6. AFTER ViewSat displays "0001", UNPLUG your ViewSat. (Turning "OFF" before "0000" will ruin ViewSat!)
 7. Connect ViewSat to your TV
 8. Connect ViewSat to DiSEqC switch
 9. Connect DiSEqC switch to LNB cable(s). 119 goes to Sat 1, 110 goes to Sat 2
[] 10. Plug ViewSat into the wall socket and turn rear power switch "ON".
 11. Automatic Satellite Channel Search for 119 Satellite using LEGACY LNB
A. Main Menu---> 3. Installation-a 1. Automatic Channel a 1. Antenna Setup
B. Select Satellite to be Searched using large Black "LEFT" or "RIGHT" remote ARROW keys
1) 119 Bird = Echostar 7
C. Insert your antenna information (Usually just need to change LNB TYPE and DiSEqC Port #)
D. 119: Echostar 7 using Legacy LNB (Usually just need to change Items 2 and 7)
1) LNB power on
2) LNB type standard
3) LNB freq 11250
4) 22khz OFF
5) TP freq 12224
6) Search option ALL
7) Disecq Port 1
8) Motor off (if available)
E. Press Remote Control OK; STB automatically searches for all radio & TV channels on bird.
 12. Automatic Satellite Channel Search for 110 Satellite using LEGACY LNB (IF NEEDED)
A. Main Menu--> 3. Installation-a 1. Automatic Channel -a 1. Antenna Setup
1) 110 Bird = Echostar 6,8
D. 110: Echostar 6,8 Using Legacy LNB (Usually just need to change Items 2 and 7)
1) LNB power on
3) LNB freq 11250
4) 22khz OFF
5) TP freq 12224
7) Disecq Port 2
8) Motor off
 13. Put channels in order like Dish (To get them in numerical order (100,101,102,105)
1) MENU --> 1. Edit Channels --> OK -->
2) Press "RIGHT" black arrow remote button 4 times to highlight last icon
3) Box below icons will say: "Sort channel list". Press "OK"
4) Press "DOWN" black arrow remote button 4 times to highlight, "Sort by SID"
5) Press "OK"
6) STB sorts channels. When done, press "EXIT"
7) "Do you want to save? Press "YES"
8) STB updates and saves information. Click "EXIT" once.
 14. You are done. Go surf your channels and enjoy!
Don't forget to read your "Owner's Manual"!
Help
ALIGN DISH or Check Signal Strength
MENU --> 3. INSTALLATION --> 1. ANTENNA SETUP
Highlight Echostar 7 (119)
Set "TP Freq." To 12282 or 12370 and have someone watch the Strength Bar--should be "Yellow" and above 70
Adjust dish left to right and up and down to maximize signal strength.
When done, re-set "TP Freq. to 12224. Then press "EXIT" 3 times.
* Insure you are using the latest PGM file
** If no picture, check Port settings for the DiSEqC switch
*** For future upgrades, the new "*.PGM" will likely be the only file you can get it from FtaVip
End C/P
Copy and paste from [link removed]
Username: Themangod
Post Number: 10
for bin files you can trust only use a good dss website like ftaindex-com http://www.ftainstallers.com dsstester-com or other great sites FTA A VIP sells support and they do not have what those listed above do for free faster.
Username: Nsanchez32
Gurabo, Puerto Rico Uerto Rico
Post Number: 11
I just want to know if some one have the new Key for a viewsat platinum
Username: Themangod
Post Number: 12
then go to one of those websites
http://www.ftainstallers.com ftaindex dot com
dss tester
dss central
ect
go become a member then get it.
Username: Marcelos
viewsat xtreme codes complete please please:-):-)
Username: Marcelos
hi folks Im a new member , and satellite for me is somenting new, all the time frind of mine find the codes and hi change in my viewsat , but now hi is on the vacations and i dont now what to do, i don t now i have to change codes in dish or bev ,please help me, thanks
