C00lsat key slot 78 & 79 question
Username: Lroy
Post Number: 105
Where is cs key slot 78 and 79 re: new 135 bin.
I have not tested the bin as yet I am running the 134. Is the 135 better?
Username: Lklives
Post Number: 4646
Norw has suggested to delete keysets 78 and 79 on bins 135.
To do this:
- go to channel 8282.
- Use the volume up button to get to 78 (or the down double arrow button to move quicker) Nagravision. Go down once so "CAS - Nagravision -" is highlighted.
- Click volume up till it says "CAS - OFF -"
- Save and do the same with 79.
Username: Bobby29134
Post Number: 93
there is a patch for this problem you know. :P
Username: Vasia22
Post Number: 41
I put 135 bin and it was runnin good exept that half of ppv didnt work but its ok, right now it just doesnt work at all, i tryed to upload different bins but still the same picture( 4 lines flying around, like someone playing tetris), and i havent turned off the 78 79 slots. PLEASE! HELP
