Indian Channels
Username: Asharfi
Post Number: 162
The following channels are not working:
SET, ZEETV, ZEE Gujrati, and ARYONE
Can somebody please help me get those channels back. They were working 1 week ago, but now they're not working. Thanks.
Username: Dallastx
Post Number: 27
which receiver are you using
Username: Asharfi
Post Number: 163
Fortec Star Lifetime Ultra
Username: Mc_sunny
Post Number: 432
AV U NEED TO DO TP SCAN FOR THAT SAT
Username: Asharfi
Post Number: 164
Are you sure it'll work? And oh yes, the admin of DssNetwork told me to tell that can you admin www.dssworld.co.nr? He/she selected you. They also selected me to be the moderator.
Username: Mc_sunny
Post Number: 433
if that dosn't work try this AV
Make sure u have the latest bin 280t
Then go to...
1 Menu
2 Parental control enter 0000 for second pin
3 Go to autoroll option at the bottom
4 Turn off dishnet, BEV, Globlecast leave on keycode
5 hit ok goto nigravision 2 enter keys
Current N2 Keys
Dish Network:
KEY00: 0C FA 39 73 91 5F F5 54 E9 56 1C 42 8B 7A CA B2 (Active)
KEY01: 66 B9 F6 53 70 ED 2A 5B 31 D5 59 D2 9F 1C 52 63
Updated: Oct 8, 2006
Bell Expressvu:
00: C9 BB A9 83 ED AE 55 D6 62 DE 45 C1 EF 14 B5 D3 (Active)
01: 5B 14 37 7E 7A 73 3C 38 C0 68 D5 A9 57 C2 13 D5
Username: Dave_singh
Post Number: 45
NEED HELP
MY DISH MOVE ON 61.5 ,CAN YOU TELL ME
WHAT ANGLE TO MOVE IT ,
Username: Mpatel
Post Number: 7
i am having problems with my pansat 2700A. i entered the new keys but still not getting the indian channels. i cant find the auto roll option on my box. can someone tell me where i can find autoroll option on pansat 2700A. Does anyone know where i can purchase just the upgrade cable and the software for pansat 2700A, i bought this box for $250.00 but it didnt come with the cables.
thank you
Username: Dude123
Post Number: 269
press 8282, press it like how you would press it normally to change the channels and you should get a screen with all the menus then go to Autoroll, leave keycode ON turn everything else off and put in the following keys and you should be able to get all the channels.... and make sure you are using the right bin for it...
Username: Dude123
Post Number: 272
Sorry here are the keys!
Nagra2 Keys
Updated: Tuesday, October 10 2006
Dishnet Keys, Provider 0101:
Key0: 0C FA 39 73 91 5F F5 54 E9 56 1C 42 8B 7A CA B2 (active)
Key1: 66 B9 F6 53 70 ED 2A 5B 31 D5 59 D2 9F 1C 52 63
Bev Keys, Provider 0901:
key0: 99 AB 62 AB 10 07 1C E8 A2 6B 2A 2A B5 B0 9C 57 (active)
Key1: 5B 14 37 7E 7A 73 3C 38 C0 68 D5 A9 57 C2 13 D5
Username: Baluja
Post Number: 101
The One: Are new keys working for Bev ? I have C00lsat and keys are punched in correctly on my C00lsat 5k with ROM 102 card.
Username: Asharfi
Post Number: 170
Hey people,
I have Fortec Star Lifetime Ultra and I have bin 279T in it. I'm not getting the following indian channels:
ZeeTv, Set, ZeeGujrati, Aryone.
I did TP scan, blind scan, re-scanned all satellites, but still having this problem. Can someone please help me. And please check if you're getting those channel too. Thanks
Message for The One and Mc Sunny
The admin of www.dssnetwork.co.nr selected both you and me to become of the admins or super moderators of their second website forums which is www.dssworld.co.nr. They looked at your posts and checked that you're helpful and hard working, so they just want you to run their second website. You're not the only one who'll be running the website, but you'll be able to the following operations:
1. control the forums
2. ban bad people
3. delete old or nasty/bad messages
Much More!
www.dssworld.co.nr is totally brand new. He/She also chose me to become the moderator of that forums. You don't have to any interview/application or any other stupid thing. Just email at dssnetwork@gmail.com and tell if you're interested or not.
This is only for the following people: The One and Mc Sunny.
Username: Dude123
Post Number: 274
Rakesh
the new keys should work for all the receivers but i just heared that on the websites the keys have been switched so try the active keys under 01 and not 00 and see if that works
Username: Dude123
Post Number: 275
Revised Keys!!!
Current N2 Keys
Updated: Oct. 10, 2006
Dish Network:
KEY86: 0C FA 39 73 91 5F F5 54 E9 56 1C 42 8B 7A CA B2
KEY96: 2F 1F 8F 26 51 18 BA 33 5F 95 1C DB EE 18 68 D9 (Active)
Updated: Oct 10, 2006
Bell Expressvu:
AUX86: C9 BB A9 83 ED AE 55 D6 62 DE 45 C1 EF 14 B5 D3
AUX96: 99 AB 62 AB 10 07 1C E8 A2 6B 2A 2A B5 B0 9C 57 (Active)
Username: Asharfi
Post Number: 172
The One and Mc Sunny.... so what's your plan about my post above?
