I dont see AUTOROLL in my 2700A
Username: Cigano
1-menu
2-second pin
3-0000
4-I dont see at the botton anything that says: AUTOROLL, Please help!
THANKS
Username: Labait
Edmonton, Alberta Canada
Post Number: 15
ive got the 2700a as well, its there....menu, parental controls,second pin, 0000, bottom of the list is autroll option...in there you can shut off all autoroll
Username: Rcfiddlerman
Post Number: 11
what bin file do you have is it a clone ...
push menu then goto parental control second pin oooo then you should see autoroll option at the bottom of your screen gothere then shut off all auto rolls keep keycode on
then goto niagravision 2 then enter your provider code then your keycode then the whole keycode
you can find the codes anywhere here someones post them either for dishnet or bev
Username: Cigano
all i see are the following:
1-SECA
2-viaccess1
3-viaccess2
4-Irdeto
5-nagravision1
6-nagravision2
7-conax
8-set default key
9-key EMU
THAT IS ALL, PLEASE HELP!!!!!!!!!!!!!
Username: Labait
Post Number: 18
weird, right under set default key mine is autoroll options
Username: Ariza123
Post Number: 8
I have an Ariza 700 and I see the exact same thing Jose sees. I'm assuming then that if there is no autoroll option, then the receiver does not have autoroll? for the past months, I had been changing the keys manually and never had to upload bin files. now I'm lost as to what to do.
Username: Nikk
Post Number: 343
Jose Fernandes..
Go to key EMU.....
